- Joined
- Mar 17, 2018
- Messages
- 13,386
- Reaction score
- 30,436
Ok that right there is just plain cool. I reckon I fall in the heavy equipment guys category as I am about to set up a 500 ton crane!
I stole it too!
Why not, I think that's badassVery Kool. I can't imagine a female significant other allowing that inside the house
I could see myself biffing it on the teeth sticking out in front. Just showed it to the wife, not only no but hell no.
Be a hell of a conversation piece with invited guests and cocktail parties
35 mph winds? Hah! Just a normal day up here on the Tundra where we only have a tree every twenty miles or so. It don’t count as breezy till the wind is strong enough to flip the lid up on your trash can, bounce off your head, and knock you senseless. Or slam the truck door closed on your legs.The Weather Service gang hit it right on the head today.
They said 75° and breezy. I think 35mph gusts count as breezy
You need to replace your suspension anyway. Just get the right K frameIt has been acquired!!!!
The little 318 will soon be dropped in when I find some schumacher swap mounts.
View attachment 1715793022 View attachment 1715793023 View attachment 1715793024 View attachment 1715793025 View attachment 1715793026
yes, but money is my problem. Unless someone on here has one they could ship to me for free, the swap mounts is the route I'm going.You need to replace your suspension anyway. Just get the right K frame
From what I found, it looked like the v8 k-frame had different mount surfaces that are higher up.But are not the k members the same? Just the mounts are different. Or so I thought....
Early A they are. Not sure about later ones.But are not the k members the same? Just the mounts are different. Or so I thought....
Yup early is like that, 67 and up there is a difference between v8 and slant.Early A they are. Not sure about later ones.
Are you sure that's not a 360. The exhaust manifolds and carb look real 360ishIt has been acquired!!!!
The driver side mount is identical on v8 and slant k frames, the difference is the passenger side. The slant passenger mount is lower and flatter.From what I found, it looked like the v8 k-frame had different mount surfaces that are higher up.
"V8'ing" a Slant K member
Sounds like good times. Not!Evening. Survived my tour in AfghanIndiana for this months. Never seen such disarray and chaos in my life.
Looks like 80’s truck 318 mannifoldsAre you sure that's not a 360. The exhaust manifolds and carb look real 360ish
unless these are not the right numbers It's a 318.Are you sure that's not a 360. The exhaust manifolds and carb look real 360ish
