'73 and up brake booster on a '66 factory V8 car
Jim Kueneman
Sonoita, Az
Anyone do this? I have a new Booster Dewey restored unit and some initial fitting before I stripped it down for blasting seems to indicate the '73 booster is going to hit the valve cover.
The pre-73 brake booster fits well. Does need minor linkage modification to work in an early A body.
Edit: By pre-73 I mean 67 to 72. The one in the pic below was from a 71 Duster 340.
On my 1965 Dart, I used a ~1999 Intrepid booster on 1974 Dart stand-off brackets. I had to angle it slightly upward with nuts on the mounting bolts to clear the left valve cover on my 273 engine (avatar), but I do have perhaps taller aftermarket valve covers. You could likely do the same with a 1973 Dart booster. I think the correct 1965 booster was a smaller diameter and longer one with dual diaphragms. I later got one but haven't fooled with it.
yea the correct one for the year is smaller diameter and has the remote vacuum tank on the fender I think.
This was the powered setup in my car with a slant 6–this was in my car when I got it, so don’t know a whole bunch about it, except that it’s likely from a 1974 car.
Although it’s not what you are asking, it gives some reference. I’ve since switched to manual brakes.
