What's your best guess?
Stroked68Dart
402 Crate Motor in a 68
San Francisco Bay Area
If you don’t mind please give me your best guess as to what I should set the timing to:
I am getting ready to set the timing on my 402 Mopar crate motor (specs are below). I was given the below timing suggestions as a starting point:
18 degrees at idle
16 degrees at 3200 (34 degrees total)
12 degrees at 12 vacuum
The motor is in a:
’68 Dart
A833 four speed
4:10 rear gear
P225/55/R18 rear tires on 18 inch wheels
The Motor:
Holley 750
Headers are 2 inches I think
4.00" bore/4.00" stroke
9.0:1 compression ratio
Big valve Magnum R/T Cylinder Heads
2.02" intake and 1.625" Exhaust Valves
Heavy-duty Valve Springs
288°/292° duration, 0.501"/0.513" lift Hydraulic Roller Camshaft
Single plane, M1 4-bbl Aluminum Intake Manifold
Double Roller Timing Chain and Sprockets
8-quart center sump street/strip Oil Pan
MSD Blaster 2 coil
MSD E-CURVE distributer
If you would like to see a couple of videos of the car see the below links.
Videos of Dart are here
Thank you for your time and help.
Bill
The answer is right there. They told you all in 34 degrees then set it all in to 34. I personally find MoPars like 37- but not always.
I would try connecting the VA to a manifold vac source.
That will give it 30* at idle. It will more than likely like that [ rpm will increase ] because of:
- the low CR
- the single plane intake
- the sizeable cam
- the low CR
- the sizeable cam
This ^^^^^^ is probably a good starting point. That's a LOT of cam for "just" 9:1 compression. Maybe run a cranking compression test and report back with that and we can nail it down even better. My guess is it will want a lot of initial timing.
Ehhhh, grandma might not like it….
:lol:
I would probably go with 12 initial to start out, And go from there. Oh yeah congratulations on that crate that's awesome!
Actually i like what was recommended. You have lots of cam, gear, and a four speed, so an aggressive timing curve should be fine. I see you have a e distributor so you can set the curve where you want. If you hear detonation, slow it down a bit.
The magnum heads have a faster burn chamber than the old style LA, so less total is needed. I might try 32 total to start with, then see if 34 or 36 is an improvement. If not, and i dont think it will be, i would go back to 32.
