dano
Evil Handy Man
Topography can kill mileage. Do you drive a lot of rolling hills?
After I drive it a bit and come back to start it, I find I need to put pedal to floor while I crank it to start.
What gears are you running? Engine in good condition and is it tuned properlyHey guys, brand new to the forum. I just recently (about 30 days ago) bought a 1973 Dart Sport 340. It has a 340 with a performance cam, Edelbrock 650 4 barrel carb, headers with the Torqueflite automatic transmission. The first couple of tanks look like I am getting a little over 6 miles per gallon. This is all city driving but surely I should be getting much better gas mileage.
I'd appreciate comments on what mpg you think I should be getting and where should I start in trying to improve this.
Thanks
Dave
Thanks
Dave
Be honest do you keep your "foot out of it?"
Make sure your vacuum advance works, better yet check your whole ignition system. And read your plugs.
Thanks
Dave
Tennessee. Memphis area.there is something really wrong. What state do you live in?
O sorry I’ll be in Tn but on the east side otherwise I’d look at it for you.Tennessee. Memphis area.
Thanks for the post. There is a vacuum line coming off the distributor and it hooks up to something on the firewall. It is the top line in the picture. Not sure what that thing is that it is hooked up to. So I'm not sure what the source of the vacuum would be.Do you have vacuum advance on your distributor?
Is it hooked up?
If hooked up, does it work?
You can see if its working with a timing light.
The reason I ask these questions is I've seen more than a few cars where the owner didn't understand how important vac. advance was to gas mileage, and engine life. Sometimes they'll say " it doesn't run right with the advance hooked up" if true, they've got some thing or things adjusted wrong. You need to find a local tuning expert. Doesn't have to be a Mopar lover, just someone who understands carburetors and distributors. Looks like a great car! A stock 340 with 3.23s should get about 12mpg in town, and with a very light foot I've gotten over 20 at 55mph.
Appreciate that.O sorry I’ll be in Tn but on the east side otherwise I’d look at it for you.
You got hilly country there?
and are you cruising in them thar hills?
Cuz that will eat gas; see post #26 re: "topography"; which is like Elevation Change, except not, lol.
My 340 gets about 8-9 miles / gal. so I feel your pain! I also have a street/strip cam, Headers, etc. 727 transmisision. Rear end has 323 gears. I have a Holley Sniper EFI sytem that is pretty well tuned but might be a tad rich.
Part of the reason you are not getting any better gas mileage is the 3 speed transmission. My car turns about 3200 rpm at highway speeds (70 mph). I'm going to swap out to a 5 speed Tremec which will allow crusing at a lower rpm as well as more fun shifting gears.
Nice looking car by the way! I love the look of 18" wheels on these cars. Here's mine.
Thanks for the post. You have a beautiful car. Do you get any tire rub with the 18" wheels? I am getting some in the rear. Not sure if a new pair of shocks is in order or if I need to go with air shocks? In terms of the gas mileage I may just have to put up with bad mileage but I believe I should be getting better than 6.
I have noticed that the car gets into 3rd gear quickly (35 mph) and while I have not noted rpms (it does have a tach) at different speeds it feels like the rpms are higher than you might expect which when I first drove it I felt would limit the top end. Which is fine I don't plan on going 100 mph in it!
disregarding the gas mileage, how does the car run? smooth, lots of power when you put your foot in it? No hesitation , misfire, etc?
The 73 is a lo-compression engine.
With a standard 340 cam, the CCP is gonna be pretty low, which means the low-rpm torque will be low. which means it will take a lotta throttle to get it moving, and more a than usual amount of throttle to keep it moving. And that tranmslates to lousy city mileage.
The usual cure for the soft bottom end is a higher stall, and for a city-car, more rear gear....... which now make for lousy hiway mileage.
When a performance cam is installed, this can, and usually does make it worse.
There are only three cures for this sad situation;
1) more cylinder pressure so you can use less stall, and less gear, or
2) more stroke, or
3) less weight.
4) A finely tuned ignition advance system can help but there is nothing that can touch decent cylinder pressure. So once again, start with a compression test
Just so you know;
not very many years ago, I had a hi compression, alloy-headed 367, with a Final-drive ratio equivalent to 1.97, that at 85=2100 got 32mpgs on a certain measured day-trip. The cam was a Hughes HE2430AL that was 270/276/110. with an Ica of 61*, the pressure was over 190psi. I ran that on 87E10 full-time, with full advance. The cruise timing was close to 60*.
The point being; it is possible to get both power and economy. Just not with a cammed-up/stalled up/geared-up, 340; yur gonna need a different line of attack.
Thanks for the post. It does seem like it takes a lot to get it going which is what I think you are saying in your first point. You noted 190 psi, what does that refer to?
Thanks
Just so you know-2;
A long time ago, I put a 318 cam into a hi-compression 340, with the early 318 heads even,installed into a 65 Canadian-Valiant wagon that was a gangbusters city car.
I would be looking at that valve in post 37. Not sure what it does, but it connects to the VA, so I presume it has some effect on VA operation. If it prevents VA operation because it is faulty, then that can kill mileage.
