Stop in for a cup of coffee
Did B Bodies play the same musical K Frame Game as A Bodies for different motor/trans combinations?
Uhhhh. Yes......
only the later year B bodies. The 62-64 series B bodies shared a single V8 K frame. To swap from the poly I have In my polara, I simply have to have the correct motor Mount brackets and the motor biscuits themselves.
now the slant 6 k was different than the v8
only the later year B bodies. The 62-64 series B bodies shared a single K frame. To swap from the poly I have In my polara, I simply have to have the correct motor Mount brackets and the motor biscuits themselves
/6 early B's are different......
Correct, you caught me before my edit
My 65 was a /6 three on the tree car. Right now my 65 Belvedere has a 69 B body K and 440 w A/T. Sets the motor too far back. Trans crossmember issues, but they slammed it in there. Crossmember bent to hell. But.... I have an original V8 65 B K frame for it. Just need to change it all out. Have a good 4 speed, will change it back to manual....:thumbsup:
Little known fact, the 71-74 B Body disc spindles that the Mopar Crowd has long said won’t work on any other Year suspension due to them being longer, actually work out perfect for radial tire specs. They end up providing more adjustment in caster and camber. One just has to make sure that they use the specs for radial tires not bias
65 is a wierd year for B bodies. Some stuff they carried over from the 62-64 B bodies, other stuff they didn’t. Then they changed it most everything in 1966. Granted with the parts combos being correct, pretty much anything but the body can be swapped over
And here’s what’s even weirder. Some of the trans stuff and electrical stuff is vastly different between Dodge B bodies and Plymouth B bodies. So you can’t mix and match. Like the drive shaft on a 64 Fury B body sedan, 318 poly/727, will not fit a 64 Dodge 440 Sedan, also with a 318 poly/ sedan.
also the push button shifter cables are completely different lengths between the two divisions.
Job security
So you know you are from Arkansas when you are making chicken gravy and mashed potatoes for dinner and you pull the boiled carcass out of the pot and set it outside to cool. When in Fargo! Do as a Fargonian would, leverage the sub zero temps!
So sorry Karl. Have they said if you qualify for the infusion?
No they think it's the new strain which doesn't respond to the infusions... (For some reason they don't test to find out which strain it is...)
However the doc said that my case is mild 0.5 on a scale of 0 - 10 and there isn't any treatment except just rest, so they gave me the option to be admitted or go home and isolate.... Knowing this hospital from before I chose to go home and rest because all of their beds are worn out and have a huge divot/hole in the middle of the mattress where your *** sits and the bed tilts and is very uncomfortable....
Plus who wants to sit in a boring hospital all day when you can be at home harassing your coffee club friends..... :D :realcrazy:
What if I am biased????
Can if you want, compared to half-assed i guess its better?
remote starter instructions for ford product
Switch must be biased when hood is in open position….
The wait for the hospital is bad... I arrived yesterday after 4 pm and didn't get taken back until 9 am today... Spent all night in the waiting room...
They just call you to the back periodically to test your vitals, x-ray your lungs, do a blood draw, at different times then take you back out to the waiting room....
The just enjoy your company is all. Otherwise they would rush you thru.:thumbsup:
A little omelet for supper. Ham, cheese, onion, mushroom, and green pepper.
