Morning, horses fed and dogs walked, time for some coffee. Good week here weather wise.
Hard to interpret your method. 16 f is below freezing, -18c is 0f16 F below freezing
x 1.8
is about 28* C below freezing.
I do that right?
So whether im covid + or not, i feel fine. Im in shop diagnosing an oil leak on a cruze. Young lady did her own oil change and said its leaking now. Been running an hour and nothing is out of the ordinary. My mind is telling me she spilled a bunch when filling it. Easy to do in these motors.
My concern is contacts. Where did it come from and who have we made contact with since?Once you get past the panic and deranged control garbage it's the flu.... You can have the flu and function just fine. Different strokes
Run timing light on cyl 6?So question what's sparkplug would you use to time your engine on a 318 if the timing marks on harmonic balancer 180° off
Thinking....I an using a 360 balancer with early timing chain cover. I had a timing tape on it. It flew off right away. So I brought number one to TDC and marked the balancer with a sharpie atRun timing light on cyl 6?
Ehhhh. Just time it by ear. Usually works bestThinking....I an using a 360 balancer with early timing chain cover. I had a timing tape on it. It flew off right away. So I brought number one to TDC and marked the balancer with a sharpie at
0 degrees using the marker on the cover. It runs fine. But I cannot see the line I put in the balancer. So I am thinking I somehow marked it 180 out...
No. Its a virus that is frequently more deadly than the the typical flu virus. It also sometimes leaves longer term damage than the seasonal flu viruses. Not that any of that matters to TJ's point. Its a virus he doesn't want to share.Once you get past the panic and deranged control garbage it's the flu.... You can have the flu and function just fine. Different strokes
Just time it by ear, you were less than 1-2 degrees off from Hoppy’s sun machine at CarlisleThinking....I an using a 360 balancer with early timing chain cover. I had a timing tape on it. It flew off right away. So I brought number one to TDC and marked the balancer with a sharpie at
Vacume gauge.Just time it by ear, you were less than 1-2 degrees off from Hoppy’s sun machine at Carlisle
I know you are a smart guy , and I'm not trying to be a smart ***. Sometimes we all lose our train of thought.Thinking....I an using a 360 balancer with early timing chain cover. I had a timing tape on it. It flew off right away. So I brought number one to TDC and marked the balancer with a sharpie at
Get in a bit of a rush and forget things.I know you are a smart guy , and I'm not trying to be a smart ***. Sometimes we all lose our train of thought.
When you brought it up to TDC you were on compression and not exhaust correct.
I had to drill out the front spring hanger to accept the larger bolts, also used longer shocks. I bought a longer rear rubber brake hose but my old one seems to be long enough, barely.So, does anyone in the group here know off hand what needs to be also changed when swapping to SS rear leaf springs? Shocks need to be longer in some cases? Anything else? This is for my 71 Demon
I am more concerned getting all in timing.Get in a bit of a rush and forget things.
The ones I had on my 74 charger came with new front hangers and reused the rears. So it may depend on the kit.So, does anyone in the group here know off hand what needs to be also changed when swapping to SS rear leaf springs? Shocks need to be longer in some cases? Anything else? This is for my 71 Demon
When you’re done doing that, come degree in mineI am more concerned getting all in timing.
Mine was a slant.Was your car originally a V8 or /6 car? Sorry, I don't remember off hand. It seems some info I am finding, the /6 had the 1/2" bolt and V8 had 5/8" bolts. IDK
