B3422w5
Without breaking my intake.
Been on there a minute, looks like
Tip of the day.find a steel dowel that fits snug inside of it
THEY MAKE A INTERNAL PIPE WENCH THAT GRIPS INSIDE, HEAT HELPS
Or you can leave it be and use it. It looks decent enough to clean up and use.
And the heat from the welding helps the process.Mine was a sob to get off i took a very large dia nut and slid it on and welded it and backed it out with a large breaker bar. It took about 3 times of welding it.
