6.4 hemi dart swap
Got some progress guys. Engine parts are in.. Mmx helped me out big time with rotating assembly and custom cam. Went with the high compression option and a custom grind. Keeping the 904 in it.. fingers crossed haha. I’m still in the fabrication stage. Fuel lines, oil, headers. Everything will be mocked up beforehand.
With those solid tubes going to radiator, will there be enough flex to keep from breaking the radiator?
Yea. Those are rubber couplers on there with room in between the rad and the tube
I see that, but they're not very long. I know it all depends on engine movement. And how soft the couplers are. Just hope it has enough flex.
Nice project!
Bitchin car. Your fab work is turning out nice as well. Im following along with this one.
Nice project!
It should be flexible enough. There will be a front to back limiter and a torque limiter on the engine
I've been eye balling that. We did the fittings out the side, that gets really tight. I never gave a thought to mounting the filter like you did. I now know what I need to do!
It’s tight but you’ll be happy you did! Side exit doesn’t work well with alternator right there..
Question for you. What's holding in the passenger side water tube in, in this picture? You cut it pretty short and not using the stock tube mount mid block. It was and o-ring fitting, did you tap the housing?
Welded a tab to tube and drilled and tapped 1/4-20 into water pump. Perfect spot for it.
Making progress on the headers. Have one more to go. Also have some track hawk injectors for it now. Ordered a hellcat 525 walboro pump. Going to do some e85.
I made my own out of .250 steel. I used tti website dimensions. Slant 6 member so I had to make my own
Do you have a link for those dimensions? Can’t find them… just picked up a BGE 6.4 today for my ‘70 dart. Was planning on making my own mounts too, got a slant 6 K frame as well.
Looking awesome! Will definitely be watching!
Mike
Mike
Go on tti website. It’s under the hemi swap headers for A body
More progress made on the exhaust. Always had X pipe on my cars but I’m going to try H pipe. Will be using Borla pro xs mufflers also.
