thesiren74
He hit really hard.
Why? Because no one has ever wrecked their car on the street or at the drag strip?
Dont get me wrong, it sucks. But if that throttle issue had happened on the street it could have been much worse. Heck if it had happened at a drag strip it could have been a whole lot worse, the speed could have been MUCH higher when the driver noticed the issue.
Track safety is something you have to pay attention to for AutoX. Typically the speeds are fairly low, and a lot of those competitions are held in parking lots vs a permanent track venue. So from one competition to another things can change a lot.
Watching that video, it seems to me that some those barriers are pretty close given the speeds that are being achieved on that course. I wouldn’t say it’s “dangerous” given that the speeds are still relatively low. But that’s definitely not the most run-off room I’ve seen at an AutoX event.
I guess because I had not seen an incident like that at an AutoX event before now. My car has been a part of my life for more than 35 years. Longer than the wife and kids. I liked the idea of doing some "spirited" driving, and that looks like a TON of fun, but I hadn't considered that kind of risk.
Anytime you drive there’s a risk, driving on the street is far more risky than most types of racing.
Bet the floor crinkled look how low the rear is damn!
He hit really hard.
These attach to the floor on early a body's so it's possible if the bolts were loose or came loose.I'd really like to see just how janky your throttle setup would have to be to be activated by the brake pedal. Sounds like either it was put together unsafe, or the guy freaked out and ran out of talent. Glad he didn't hurt someone.
I took a look at that video.Wonder if functioning ABS would have helped the guy in the truck.
So I had something similar. I had my '67 Barracuda in a shop since I was working out of state. It dragged out and the clincher was when I took a couple days so I'd have a long weekend to work on the car after they had the new engine in. When it wasn't ready because the owner had some Trans-Am cars from bigger customer, I asked if they had a flatbed service they worked with. Kept it business like but that was it. They got the new engine installed but not even fully bolted up. Had it flat bedded to my garage and that's where it sat. Made a seperate trip to pick up the old engine after buying a stand and borrowing a cherry picker so I could unload it.If I had the time, space, knowledge, and equipment I would just bring it home. Even if I had the time, space, and equipment I would bring it home.
I think the answer is yes, but only a little.
Even a basic ABS should have pulsed the front brakes allowing for slightly better traction and maybe allowed for some steering.
But not enough difference to stop or turn it before the barriers.
Comparing with other drivers in that same video, the brakes were applied too late and too hard.
Ideally we'ld like to see all four wheels lock up together on dry pavement, although auto manufactures always lean toward front lock since its safer. But IMO that should happen on slick surface. The rear wheels can contribute significantly in the begining of braking application. If I was looking at this for lessons learned, I would want to explore the brake setup as well as driver decisions.
Other points from the video with the truck:
* Watching the other drivers in that video after watching the Barracuda it seemed to me all were accelerating after they cleared the finish lights. I'm not certain - just going by when the annoucer makes the statement about best time. Generally when we see people doing that at our events, someone is going to talk to the driver. Many times there will be opportunity to accelerate toward the finish and through the lights. That's different, and there will be room for the car to stop even if you do lock up or spin - although you may hit some cones.
* SCCA layouts are designed for participants to drive as close to 100% of the car and driver's capabiliity, and when that is exceeded the penalty is hitting cones (2 second penalty each cone) or going off course (no time scored). We're not seeing cones get hit during the course runs in the video. So its reasonable to conclude that Goodguy's course design concept is different.
* Just because an event is SCCA sanctioned is no guarentee there will be no incidents resulting in injury to vehicle or people. But TWO crashes in the same location on the same course in the same day raises a lot of questions. I would encourage anyone who does participate in a Goodguys event, or anything on a course setup like that (eg Carlisle) with physical barriers or poles so close to drive at 95 or 90% of what you think you and the car can do.
* Finally, SCCA sanctioned autocrosses are 'non-spectator' events unless specifically noted otherwise. This is in part to reduce motivation for "watch this!" driving. For the same reason most will not allow a second person in the vehicle except for an experienced instructor. At least not until you have some reasonable amount of experience yourself.
Those are just some things to think about when seeing these videos. Its sad to see anyone's vehicle damaged as occured at that event. The owners obviously put a lot of time and effort in to both, even if they had not fully tested them out. Autocrosses can be a fun and relatively safe activity to push yourself and your car.
Those Goodguys autocross layouts are poorly designed. They are trying to put on a spectator show in event locations with limited area. It's a totally compromised situation.
Extremely tight courses with barriers in the run-off areas.
Just go to a SCCA autocross that are designed for safety and the racers.
Or just remember that you’re there to have fun and you’re not gonna make up that much time at the stop line.
But since they do attract people that don’t have a ton of autoX experience they also have a lot of folks that don’t recognize safety things like that and still go 100% when they should dial it back because of the course.
It would be nice if there was something a little more in the middle, SCCA is working on it with CAM but they’re still super formal for a lot of things and that makes it less approachable for newbies and weekend warriors. But then Goodguys is like a total free for all. If we could just get something that was safe but also less about rule books and season points and standings it would be great. Something so folks could go out and have fun a couple times a year without spending a crap ton of extra money to compete in something that they’re not going to attend enough events to make a difference.
