Do you know anybody with a porta-power?I need a diesel truck slide hammer
Maybe if it is held together with rust!Abody...worth about $400
Yeah good idea if your built like a sasquatchAttach a chain to the studs and hang the chain from a tree then pick the housing up and slam it up and down. The housing then becomes the slide hammer.
I love outside the box thinking!Attach a chain to the studs and hang the chain from a tree then pick the housing up and slam it up and down. The housing then becomes the slide hammer
Or a out of control incident with a curb or ditch.ton of HP put into the axle to bend the housing like that
maybe if you took all the carrier bolts out it would let the center section enough give to take some of the bind off. Wouldn't take much time and worth a shot...
Way back in posts 10 and 13...maybe if you took all the carrier bolts out it would let the center section enough give to take some of the bind off. Wouldn't take much time and worth a shot...
Pics?I have a fixture for straightening rear end housings. I mostly do ford 9" but I have the stuff for an 8 3/4. Shipping is probably a deal breaker unless you have a way to get it to me and back. PM me if you think it would work out.
