Driveshaft length for a Viper tr6060 and 8.75 rear
SRT_DSTRHOLC
"There is never enough horsepower...."
California
Hello! I have some measurements, but I am wanting to double check with you guys to see what length driveshafts you have been running (length wise) to see if I’m in the ball park. I always like to double check
It matters what your car is here.
No 2 cars are ever the same when custom built by different people. Yours will be unique. Your engine trans combo maybe mounted further forward or back than the next guy. Different mounts etc...And why would you use someone elses numbers ? Just saying...
Again. I don’t need a full conversation off topic. I get how it works. I just need some numbers. Thank you for your input. Still looking for numbers.
52- 37/64s Cut twice , then measure once !
Not sure if your Viper TR6060 has the same overall length as the aftermarket T56 Magnum...
In my Duster with a 340, factory 73+ spool mounts, T56 magnum transmission and a ToddRonn crossmember my driveshaft ended up being 45 3/8" back to my 8 3/4 with 1350 joints.
Not sure if your Viper TR6060 has the same overall length as a the aftermarket T56 Magnum...
Well i got 48 3/8 and 48-1/2 depending on where I took the measurements. So again, I know everything is different, including that I have GST watts link and need to make sure my rear is where I want it too
