Good eye! I believe it is.Is that the metal id tag in post 9 second photo?
Looks close but non of my Picts match the 3 they using . Also like Napa - says you can't buy this product as its " not available " for them to even order in the store same goes for Napa , auto zone , advanced , oreileys .
The C6018 that Autozone shows is the correct carburetor. It's the same as you have. It's just not available anywhere. I think if you want that particular carburetor, your only choice is to rebuild it or have it rebuilt.Looks close but non of my Picts match the 3 they using . Also like Napa - says you can't buy this product as its " not available " for them to even order in the store same goes for Napa , auto zone , advanced , oreileys .
I've not but if it's "that" close to fitting, I'm sure you could use a low profile 2 barrel air cleaner. This is hot roddin fifty plus year old cars, man. You're not going to find anything that falls together without some modification, unless it's dead stock.i saw on vice grip garage video where he buys a duster from Dylan mccool , Dylan had used the very adapter that was suggested me to get and is using the 2bble 318 carb on its Slant . But no air filter lol . My guess cause it's doesn't fit cause I tried it too with factory air box . Anyone seen that video ?
None of these fit actually . The bolt pattern is not the same as the fords
Yes but this is not a new one or even operational this is for rebuilding. And they don't have in stock as I was claiming I can't find anyone making new replacement copies like they do the BBD Whicj is what I'm running now . I cut a hole in my hood and put a scoop on it so I could close my hood.found one..
CARTER 4956S BBS CARBURETOR
Carter BBS 4956S & Others, 1970-71 Chrysler Dodge & Truck 198"-225" Motor
