[Found!] 67 Cuda 273 to 340, 360 engine mounts.
Dmopower
Looking for a set of engine mounts for my 67 cuda. It came with a 273 and I need mounts to put a 340, 360 in it. Thanks.
You can use the 273 mounts and use a small spacer to mount them on the 340. 65'
Does that apply to both sides? Are they strong enough to hold 525 hp with gears and traction when this is done to them. Thank you for your time and help.
Passenger side is identical to the 340 mount, only the driver's side needs the spacer.
As far as strength, they're just as strong as the factory 340 mounts you're looking for.
Sorry I don't have what you are looking for but would be interested if you plan on selling the 273 mounts
I will keep that in mind. How much would they be worth to you plus shipping? I have them and they are on my car now as it's drives.
I'd definitely use a torque strap with that setup regardless of which mounts you use.
I
8 sets left this is the last single I have and the last one to be sold by me on this forum due to Steve giving my name to OP and the respectful way I was asked for one. It will be in the mail tomorrow.
