I never said you did. For a minute I was attempting to pry some knowledge out of him. I'm not very good at that. He's not stupid.I would never agree to that statement as a 100% fact because it’s not.
What I was getting at is the fact that this guy wants to basically say let's use the same top end to make the same power with both engines. When someone gives an explanation as to why it won't pan out he says yeah but if we change this this and that it should work. Which is fine and it makes sense but ya can't sit there and do that with every explanation given. It's a go nowhere type of deal.
Idk man. My gut tells me it will make a little more over all but less per cube. The heads are small.So make your engine 408 inches and how much power will it make???
Explain to us why there is a difference in rpm.
Let me see if I can help you out.
I don’t care what head you use, if the rockers are NOT a offset, that port is good for maybe, MAYBE 370 inches before it becomes a choke.
Think about this. There isn’t an aftermarket head out there (again, with non offset rockers) that can compete with the W2 head. Not one. Not even close. And the W2 head was based on 340ish inches.
The engineers that developed that head weren’t idiots. And look at the lengths they went to make a competitive cylinder head.
And from personal experience I can tell you the W2 head, FULLY ported to square, with a 2.100 intake valve and a tunnel ram is about used up at 8000, maybe 8200. That is a fact.
Now drop those heads on 408 inches and watch them struggle.
I say it all the time. Architecture matters. You can look at some of the head available for SBC engines out there. To make real horsepower they are using heads that flow over 350 CFM at .500 lift and have a port size (and a really nice shape) that 25 years ago would make a BBC blush.
I think way too many don’t understand how head deficient these engines are. And the upshot of that is it takes a bunch more cam timing to get the same RPM (at whatever RPM that we are talking about) out of an engine that is induction (and valve diameter) limited.
The best remedy for that is reduce the stroke.
Basically it takes a certain amount of fuel and air within a range to make x amount of hp of course there’s other variables.
Just off the top of my head guess say 400 hp is about 550 cubic feet of air per minute, cfm.
now you got a 318 and 360 how are those engine gonna displace that amount of air and fuel ?
let’s just say were operating at 100% VE so a 318 is .184 cubic feet and a 360 is .208 cubic feet per cycle that’s how much of the 550 cfm they can process in one cycle which is two revolutions. So how many revolutions “rpm” does it take to process 550 cfm for both engines? 318 = 5978 rpm and 360 = 5388 rpm for both to move 550 cfm.
Of courses there variables so not gonna be the exact out come but why they do operate at different powerband.
See, my argument is in line with this. Get good heads, and the 408 will outrun the 383. But not if the 408 is crippled with non offset heads.
You make my point. What he’d can you fit to the 408 that you can’t fit to the 408?? Even the W2 is undersized for 383 inches.
If you could get into some W9’s or similar you might get ahead of the 383, but I know that the W7 head was developed from the W5 for 350-370 inch engines. At that time I think they were in the 8700-8800 RPM range. That was with a single 4.
So taking that head over 400 inches and it will start to lose VE right quick unless the cam timing is adjusted. And you will hit a point where you really gain nothing up top an you just kill the middle.
That’s the issue. I like to consider the cross section and when you do, you see how limited the induction we have to deal with is.
Even for street, street/strip, strip/street stuff.
... which to me means 410 ve% is lower than the 360.
So? The bigger more is still making more. Your question wasn't whether it was making ENOUGH more.
That was torque, it made 2% hp gain of 8.5hp at peak.
Just curious
What would your 500 hp combo’s be for a 0.060” overbored 340 block so 4.10” with each one of these strokes 2.96”, 3.58” & 4”
and what would your 600 hp combo be for a 4.375” bore 400/440 block with these strokes 3.38”, 3.75” & 4.25” ?
shooting for pretty close to those hp goals for each.
And here's another example of size/spec/hp currently running in the '69RR.
589ci/mega block
-13 365cnc Indy heads
2.30/1.88 valves
440-2
Herbert .625/.625"-260/270@.050
10:1CR, old 950HP DP
2.1/8" TTI step hdrs.
So it made more..
Also, peak isn't the whole story.
How about this build, I'm guessing 550 if everything is right:
340 bored .030 over.
Trw flattops, block decked so pistons are .035 above deck.
Open chamber W2's, 11:1 compression
208 intake valve flow about 300 cfm @.600
M1 single plane intake.
Bullet solid roller, 296r
262 @.050 intake 266 @.050 exhaust. .640 lift 109 lobe sep
Guys you're being played! He bases his "facts" off theory and I read it (insert your choice) one time.
I'd like to see how many years of engine building are represented on this thread, this is real world experience, not theory.
Woooo ragazine builds. Talking trash here I see. They throw numbers around like I throw horseshoes. Scattered.
The mopar one's are built by some of the builders on this site, so their too liars then?
And since I don't and most of us don't have a dynos we got to extract from where we can do they lied more when building less displacement ?
Let’s just say they stretch the truth and many gets free parts to test. Dyno number to me don’t mean diddly squat.
