Anyone have any recommendations for an air compressor that will do a good job with HVLP paint guns? Needing to get one that won’t break the bank to install in this barn
Had to be even more painful in the land of tax and take your moneyHey guys. Getting stuff together for taxes. No fun.
What ever you buy, THE MAX PSI is not the important spec. It is CFM At 60 or so psi. It needs a belt, no airless will deliver good CFM. A large tank is just a crutch of low flow. Look for a good used one. They are out there.....ones that were north of a grand new, for a few hundred dollars.... you have 220 in your new shop?Anyone have any recommendations for an air compressor that will do a good job with HVLP paint guns? Needing to get one that won’t break the bank to install in this barn
Like this for 300 bucksWhat ever you buy, THE MAX PSI is not the important spec. It is CFM At 60 or so psi. It needs a belt, no airless will deliver good CFM. A large tank is just a crutch of low flow. Look for a good used one. They are out there.....ones that were north of a grand new, for a few hundred dollars.... you have 220 in your new shop?
Thanks for reposting. Your's is the one I saved.Hey @toolmanmike
I appreciate the call out in this, but I did not make the picture, it's just one I saw on here and saved for reference... (I don't to take credit for someone else's work when I didn't do it...)
I just reposted it for others to benefit from...
Gas Cap chart
Big piston is for the volume, small one is for the pressure. (second stage)Like this for 300 bucks
View attachment 1715990470 but you do not need a two stage compressor. Where one piston is smaller then the other...
You own this?
Kind of Leasing for now.You own this?
and 9,000,000 of those are posters rolling their eyes hahaReplies:
457,700
9,019,723
And this thread keeps on coming!!!
Like a train wreck, you just cannot look away, no matter....and 9,000,000 of those are posters rolling their eyes haha
We are family here! (group hug)Like a train wreck, you just cannot look away, no matter....
Just logged in (after finding my password)OK so what's the over- under on the screaming and gnashing of teeth about the site format change
