Low buck 360 build
Time for final block and other parts cleaning and paint....
I blasted the living hell out of everything with the pressure washer. Everything super degreased and scrubbed. Lots of cleaning with the engine brushes. Put it all together with a few screws and bolts. That way I didn't have to mask anything off. At least not too much. This engine is going to have a spray rustoleum job. It's cheap and easy :D
Before primer:
After primer:
I used the rusty metal primer. Sprayed 4:3:1 paint/ thinner/hardener
I then mixed the red and yellow to make something kinda like orange. It didn't turn out as great as I'd have liked but I'm still quite pleased with it. I think I spent $30 on paint and thinner and another $10 in hardener. And I have lots of paint leftover.
Mixed the paint together. Red plus yellow makes orange! Ended up taking more yellow than red to get to the shade that I wanted.
All in all I'm pleased with the outcome. It'll be a quality engine paint job that'll hold up pretty well. It'll look good with a Carter and a chrome air cleaner and some headers :D
Before primer:
After primer:
I don't think the crank pulley is going to line up with that water pump pulley you have on there.
Working on installing the cam bearings and the crank today.
Mic'd all the journals and it's in spec on diameters. Remarkably well ground in fact. All mains 2.8000-2.8002.
Clearance with the engine tech bearings is on the loose side. Checked with a dial bore gauge they're between 0.0025-0.0030. on the high side of the spec but I think it'll be fine.
Got all the cam bearings installed yesterday, and the crank installed too. Also lapped in the valves and even got one of the heads assembled. Next up I'll start looking at pistons and rods.
Assembling the other head today. Might go ahead and stab in the cam with ample cam goop applied.
So I ran into an issue. It seems either my cam or bearings are too tight. It's actually something I noticed when I was checking piston to valve clearance earlier. But those bearings were completely shot. I suspect the cam journals on this cam might be on the large side. Anybody had any experience with this?
I have another cam I can pop in and see if it's any better.
Scrape the bearings and make it fit.
Use some blueing on the bearings and then slide the cam in and turn it. You‘ll see the high spots. Take them down with a bearing knife.
Before primer:
After primer:
What thinner and hardener did you use? Looks great!
Yeah I suspect I'll have to do this. The engine tech bearings were awfully tight on a couple journals though. I ordered some clevite.
I actually have found a cam, locally, that has had the diagonal slots cut in the journals to help with this issue. I'm going to give that a try.
So I did get a bearing scraper knife. Played around a bit with the enginetech bearings. The finish after scraping though. Looks pretty rough. Just wondering if this would work? After a fair bit of scraping they finally fit over the journals decently. The feel is ok. Just wondering how tolerant this would be. I worry the bearings will just get gouged up. I'm hoping the clevite bearings will have better out of the box fit. These engine tech were very tight!
The cut camshaft will work better than a bearing knife. Much more uniform. It might be dated and archaic, but it works well.
If your knife is nice and sharp you can get a very nice finish but you have to just take small, smooth cuts and take your time.
Or you can use the cam with the grooves if you have one.
Here's some shots from my playing with the cheap bearings. They needed a lot of cutting to properly clear.
This is what I have found over the last few eng builds. Cam brg size is all over the place.
Last engine I built for my 318 , the new cam bearings were fitted but I could not get the camshaft in. After much looking I decided it was the second from the back that was tight. I tried to use a brake hone but that failed so after a while I found a piece of pipe the required size, happened to be my alloy floor racing jack handle and taped some wet and dry sandpaper around it and just put that into the bearing and kept turning it while lubing with WD40 until the camshaft fitted without binding. It worked for me!
Ok, so I spent the day pretty much, working on this engine. First thing, I had to clearance the cam bearings. I ended up installing clevite cam bearings, hoping they'd be better than the engine tech ones. They weren't. So I purchased a used 5.9 magnum cam locally. I slotted it at 30 deg on a staggered pattern.
This took awhile to work. My bearings were very tight and I had to tap the cam in with a hammer, turn a few turns, tap again, repeat. Took awhile. But this method works.
Next up I installed the crank, cam and timing chain, now it all spins nice and smooth.
Next stop, pistons. These are 4.030 pistons and rings. They were put together and tossed in a crate. Got dirty and rusty. So I cleaned them up.
Once all was cleaned I installed the bearings and torqued for a clearance check. All rods were between 0.0015 and 0.0020 so pretty good. I'll match the small rods with the smaller crank journals.
