Time to play another episode of WHAT'S THESE PARTS !
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Finally found some time to go through some parts I had laying around. I can use some help ID ing this stuff. Thanks in advance !
First up are yhe fiberglass reproduction parts . Marked Superbird mag. Any idea on these ?
@dadsbee
Next up is this hurst shifter. Came with a 833 5 speed is this actually a mopar shifter? Note the bushings for the rods.
These a usually the hard gear grabber parts for racing.
Straight linkage with bushed rods etc. Some had reverse lockout by pushing lever down.
The shifter is a Hurst Competition Plus, they had larger holes and those brass bushings in them, popular upgrade and I heard they work good having those bushings
I believe the originals where sheet metal
They indeed were sheet metal from the factory.
Al, I'm pretty sure the proper name for them is "Wing washers" They kept the tops of the quarter panels from flexing from the weight of the wing, aerodynamic force on the wing, and heifers laying on the wing to get their pics made!
That being said, I don't know if the ones you have would have been for a Bird or a Daytona, or if there is even a difference. You might look em up on Janek Wing car reproduction site to see, and check on a price.
