mopowers
Probably a stupid question, but what's wrong with the way the factory ran them?
The factory routing puts the fuel line exactly where the "rule book" says it shouldn't be - along the inner frame rail next to the trans bellhosuing. Right or wrong, factory methodology does not necessarily equate to what is in the rule book.Probably a stupid question, but what's wrong with the way the factory ran them?
Looks like the factory location would suffice per NHRA as long as it's either steel braided or protected by steel tubing (from 2021 NHRA rule book).The factory routing puts the fuel line exactly where the "rule book" says it shouldn't be - along the inner frame rail next to the trans bellhosuing. Right or wrong, factory methodology does not necessarily equate to what is in the rule book.
I actually had it the OE way before and I never got hassled about it so maybe this exercise is a little overkill. You could even go so far as to interpret the rule as being for cars with manual transmissions only since the text clearly says "flywheel" which would not apply to me at all. Problem is, the wording is vague and there's always going to be the one guy who does not know you and wants to enforce the rules the way he interprets them.
Case in point - one guy almost wouldn't let me run one time because of the factory RF brake line on the firewall. He said it either had to be covered with spring guard completely or moved. I said it's 100% untouched factory stock, what do you want me to do? He said OK but next time it has to have the gravel guard or be moved or I couldn't race.
The car is going to be faster now and consequently it has a roll bar. A tech guy is going to see that and start looking at things a little more closely. The closest track to me is 2 1/2 hrs. away. I'd hate to get up at the crack of dawn, drive all that way and get bounced before making a pass. Based on my brake line story above, it's not that far fetched. Better safe than sorry.
I’m using a 904 trans. Rarely, if ever do you hear about them violently exploding at the drags. I’m sure it has happened but I don’t recall ever reading about it occurring in any sort of dramatic fashion.Looks like the factory location would suffice per NHRA as long as it's either steel braided or protected by steel tubing (from 2021 NHRA rule book).
All good points. I was strictly looking at from a standpoint of why over-complicate it? Either way, you got it done, so that's all that matters. Nice work as always!!I’m using a 904 trans. Rarely, if ever do you hear about them violently exploding at the drags. I’m sure it has happened but I don’t recall ever reading about it occurring in any sort of dramatic fashion.
OTOH, 727s do have more of a tendency to blow up. At the level most of are at though I’d say not enough to ever be concerned about. The rule is for that one stupid time it could happen even though for 99% of the people racing Chryslers that would be never.
Regardless of what the rules say, would you trust “steel braided hose” to be sufficient protection against a wayward ring gear? Or, would you want to figure out how to facilitate installing a 16” length of 1/8” wall steel pipe in that area?
Again, I‘m not interested in fabricating some sort of shield just to be able to run the line through that spot. It is pretty tight quarters next to the torsion bar mount. It’s also right next to the header collector which radiates heat. Nothing like cooking your fuel inside a heavy steel tube before it gets to the throttle body. Again, no method is perfect.
I will also argue that the factory routing does in fact expose the line to road debris to some degree. (Ok steel hard line vs. flex hose with aluminum fittings but it’s not a big stretch.) I’d say it’s especially true where it crosses under the right rear frame rail and from the outer pinch weld to the inner frame rail. Where it runs along the inner frame into the engine bay there is nothing between it and the road. Can you justify saying that one 6” section of hose I have in the wheel well is any more susceptible to damage than the OE line?
I see you've already made your choice - and you sure have a much nicer car than mine!! You mocked up a line similar to what I have but only better. I went ahead and took some pics of mine just to close the loop and show what I have. The previous pics I posted show what it looks like from the top side. These are from the wheel well side. Again, I like this as it minimizes the heat exposure to the fuel in the lines.Do you have pics of how you routed the lines in the wheel well? I can guess how you did it but pics always help!
I installed the steel pipe. Like rmchrgr I went through all kinds of mental gymnastics trying to figure out how to run my supply and return lines correctly. Finally bit the bullet and decided to run the 16” of pipe. Crappy part is the track has inspector’s have never looked at…Looks like the factory location would suffice per NHRA as long as it's either steel braided or protected by steel tubing (from 2021 NHRA rule book).
Mine with a Hemi was to close to the big tube headers. Especially, with the diameter of a #12 line.I have a dumb question...
Why not run it inside the frame rail.
Yes I do drive mine on the street more than you'd think. The line is pretty tight to the inside of the wheelwell - the pic may not show that too well. The line is one long one from the pump by the rear axle all the way to the regulator on the inner fender so no connections until the regulator. It enters the bottom of the regulator straight on so no bend needed up there.There you go, thanks DemonX2 and Jeremiah. Presumably you both drive your cars on the street?
For my own edification, I spent an hour trying to bend a hard line to fit in this spot and it's definitely a no-go. No way to get the bends tight enough.
Here's the better-fitting hose.
Thread dig i have thought about this for mine as no idea how ill get fuel line into bay given how much space the extractors take up.I have a dumb question...
Fuel regulator must be mounted at least 6 inches ahead of the firewall.I thought the fuel line had to enter the engine-bay, something like 12" forward of the cowl.....?
Where did you end up running yours as i have the same issue, even worse so as i need to pass engineering and all fuel lines must be 100mm from pipes. My brake lines will potentially run in the cab and up the fire wall and out up higher than pipes like the australian a bodiesMine with a Hemi was to close to the big tube headers. Especially, with the diameter of a #12 line.
Mine is very similar to this one but higher up and further towards the front.Where did you end up running yours as i have the same issue, even worse so as i need to pass engineering and all fuel lines must be 100mm from pipes. My brake lines will potentially run in the cab and up the fire wall and out up higher than pipes like the australian a bodies
