moparraceman
have a set of rear brake drums [DART VADEAR STYLE] guess came on 1971 a bodies and other years iam sure ,what are they worth want to sell them ?
Come one man, small bolt "bell" stylesYou'll need a photo or two amd some measurements. Our chrystal ball is broke!
I know which ones they are. Half the members here may not. What kind of shape are they in? I can't tell that from here either.Come one man, small bolt "bell" styles
Heavy duty wit the extra cooling fans
Going rate?
37 cents per pound
No, other way around, most passenger cars are .060 over. .090 is generally trucks, AKA 11-12" and larger and also heavier to start with. The other thing you want to be careful of, is they don't necessarily wear "flat" across, so the mike may hit the "high" spots.Yup, need a photo of the drums, one showing the micrometer measurement of the current diameter, and the max specs of those particular drums. Most are 10.090" but not all are. Some are 10.060" max specs.
