Unconventional
I wonder if that was an apprentice wage. As a step 1 apprentice I made 60% of journeyman scale.
I'm guessing early 70s ad.I wonder if that was an apprentice wage. As a step 1 apprentice I made 60% of journeyman scale.
That was the rate for assembly worker .I wonder if that was an apprentice wage. As a step 1 apprentice I made 60% of journeyman scale.
'66 it saysI'm guessing early 70s ad.
And now it's $30 an hour or more and still not enough for a young family I would think.The journeymen when I started in '77 were makin' $10/hr.
Not bad
Yeah I didn’t think it turned out too bad. Considering my only tools are a hammer and a 2x4 to make that since the squatters stole everythingNot bad
Got a pic of your filterIt's out again
Fluid was clear... not burnt
Schmutz on the filter over the pickup..
New TC nose is about 1/8 longer than the OEM. Still need to check the slot depth
I find angle iron gives you a sharper bend.Yeah I didn’t think it turned out too bad. Considering my only tools are a hammer and a 2x4 to make that since the squatters stole everything
Not bad
Noted! Thanks.I find angle iron gives you a sharper bend.
Carburetor/Air Cleaner clearance device?
I mean a full shot, I’m not seeing the second hole
I did the same thing a long while back. Works good, but it was too small for this job,I took two 30” round tubing of different diameters, welded to a 2x2 square tube same length and
Welded together with a small gap. A pipe anvil, great for bending sheet metal where you need a radius.
Nope.Carburetor/Air Cleaner clearance device?
Ummm I’ve never heard of that being done successfully while maintaining the pushbutton function. Really curious how that would be possibleI had it converted to a single pump when the initial build was done
And I bet they don't pay all the benefits like they did in 66, either.And now it's $30 an hour or more and still not enough for a young family I would think.
