Stop in for a cup of coffee
And I bet they don't pay all the benefits like they did in 66, either.
Yea Rob true and everyone wants to pay a bit more per hour if you work under the table and no benefits or workmans comp. Not a good idea if you get hurt on the job it's your own ***.
Carburetor/Air Cleaner clearance device?
Need to run the beads and get the drain plug holes popped in and then I should be ready to burn them in place
Tell you what. Taking it out for the third time is pretty easy.. :lol:
That’s probably how I got so good at pulling Nv4500s and Nv5600s. When I was truck pulling busting clutches, eventually I got to where I could drop the trans and t case, new double disc clutches in about 2 hours time to back running.
The ***** was the triple discs and the big *** QUAD disc clutches. For every disc, you had a flywheel too, which makes them HEAVY!
Hey Chris just my 2 cents and not knowing what your plan is
but instead of welding it to the the 1/4 panel if that's your plan ya might want to use metal bounding glue there. No worping on the 1/4 panel that way.
