Stop in for a cup of coffee
Youngest son tried out my cheap little chief smoker and did some cream cheese, It's good but needs some Jalapenos.
It's out again
Fluid was clear... not burnt
Schmutz on the filter over the pickup..
New TC nose is about 1/8 longer than the OEM. Still need to check the slot depth
I took two 30” round tubing of different diameters, welded to a 2x2 square tube same length and
Welded together with a small gap. A pipe anvil, great for bending sheet metal where you need a radius.
I did the same thing a long while back. Works good, but it was too small for this job,
I had it converted to a single pump when the initial build was done
Ummm I’ve never heard of that being done successfully while maintaining the pushbutton function. Really curious how that would be possible
