Big Inch Smallblock
I have zero personal experience with a small block Mopar. I know an acquaintance of mine has built a 471 and a 501 small block.
Are you looking at a crank/rod/piston kit, or piecing something together? I would look for a kit that uses small chevy rod journal sizes, Chevy rods and pistons with Chevy pins. Everything would be lighter than Mopar stuff, have better selection of rod quality and sizes, more room in the lower end of the crankcase, wider bearing selection.
Lighter stuff will stress the block less, considering the big stroke.
My stoker is at 421ci with a 4.125" crank. I got the forged crank/rods from Ohio Crankshaft. Pistons are from Ross. Chevy journals.
The block was a 91' LA roller. We did not have to clearance the block. With a 4.250" it's possible you may have to touch it. Just make sure whatever oil pan you get will accommodate the stroke. I also learned through dyno testing that the extra cube will eat the cam. I went way too small with my initial cam duration. I'm in the process of swapping that cam for a larger one now.
I did a thread about it if you search my profile
Where do you get a 4-1/4 crank for a small block now? Is that going to be a billet only piece? What's the intended end usage, street and strip or strip only?
I’ve never owned one, but I thought the Hughes 426ci kit had pretty decent parts.
4” stroke Molnar crankshaft, but my R3 is at 4.18…. so Im around 440 cid
The big inch LA is long been in my mind. Several years ago I decided to do it but when I called Rod for the crank he had sold his last one 2 days prior. He said he didn't know when he would get more. I think it would be neat to have a 454" SBM. I would go 4.125 X 4.250. Use would be a bracket car which should get well into the 9s. Certainly finding one would be a problem but I'm sure one will show up but it must have 340 size mains. All I need would be crank and pistons I've got a few rod choices all with 2 X .927 config, a good X block which will go to 4.125. I also could go 4.125 X 4.125 for a 440 inch engine. There's a 4.250 crank for sale now but it has 360 mains. Just dreaming but if the right item comes along I'll go for it. It would be fun!!!
Personally, past a 4 inch crank, I don’t really see any advantages in going bigger from a performance standpoint.
Most heads available for small blocks aren’t even capable of taking full advantage of a 4 inch arm, much less more.
just shorter piston, more side loading, and worse rod ratio.
I actually think the 3.79 deal might be the most optimal choice out there.
Im building a 3.79 now >4.00 and airflow becomes limiting factor for most reasonable / feasible builds. Nothing wrong with a well built 3.58 or 3.79 stroke 340 for most people. @PROSTOCKTOM on here is a good choice for crankshafts and rods.
If I remember right the huges kit use
If I remember right the huges kit use Molnar crank and rods in there kit. I tried to order the 426 kit from them last year. But they were out of cranks at the time and told me they didn't know when they were going to get more in. I talked to them a few weeks ago and they are just now starting to get some crank kits on. When I get some more money saved up. I am going to buy there 426 kit at 12.1+ compression one, for the 360 magnum. That I am going to put in my 91 dakota sport or I might put it in my 1965 plymouth valiant, but it's going to need lots of work before it's race ready. I am wanting to run low tens or high 9 in the 1/4 . Don't know if I can do it. But I am going to try. Lol
The exception to this is the W2 and up series full house heads with 350 plus cfm airflow. There are some big inch small blocks turning some high rpm with those setups.
Gonna see how it goes on my build. Never built a serious SB before. 4.125 stroke X 4.175 bore. I'm not overly optimistic, as we've had great success with pumpgas hemi engines. New world for me.
Starting with this......
Lots of SB Chevy guys were using these for their cars. We got this cut/unused one, from one of those guys. Lots of chips ahead...
Chevy guys were haulin'-*** at one point with that intake. Lots of NHRA Bowtie cars used them. It'll probably work out better with our own lower, anyways. It'll get lots of welding, milling, and grinding.
I’ve never seen a W2/5 go better than 355.
W-7-8-9 will though.
Man!! They de-flanged it!!
I’ve seen the Chevy guys use MP intakes before as well as some other stuff. They like to break our balls over us using Chevy karts but we all know it’s a multi way street where using your head is best and sticking with your brand could be a limiting factor.
Whatever works to make your stuff quick is what you use.
Never seen a W5 head go remotely close to 355. For one thing, they flat aren’t big enough.
I can say this for sure, even a good W5 head is more than used up with a serious effort 4 inch crank deal. You need go no longer stroke on anything like that. Those heads were designed for stock stroke 340-360 mills. Not 400+ inch stuff.
I've been very pleased with my 4.125" stroke deal. It made peak power at 6750, I normally don't turn it over 7k and it pulls like a freight train..........everywhere!
They will go that high. I was at 340 on mine, but it took a **** ton of work.
I think (THINK) I could get close to 400 out of them, but by the time you did all the work you might as well try and find some W7’s because that’s what you’d have.
