I’ve seen someone’s report on them go a bit past 330, IIRC.Never seen a W5 head go remotely close to 355. For one thing, they flat aren’t big enough.
I can say this for sure, even a good W5 head is more than used up with a serious effort 4 inch crank deal. You need go no longer stroke on anything like that. Those heads were designed for stock stroke 340-360 mills. Not 400+ inch stuff.
Shady Dell? I forget. The W2 if carved to the high heavens will get crazy numbers. IIRC, Dick Landy carved ridiculously huge rectangle ports. It’s porting way beyond normal.
From a been there and still doing it guy. Thanks for that reply.I've been very pleased with my 4.125" stroke deal. It made peak power at 6750, I normally don't turn it over 7k and it pulls like a freight train..........everywhere!
