TT5.9mag
Two atmospheres are better than one
Heat range will be correct when two-three threads around the base are darkened. Timing will be about perfect when the light coloration on the ground strap just about reaches the base.
It's square not sharp. I just zoomed in from one of the first pics. What do you mean "starting to nip the end"?It’s hard to tell but is the end of the ground electrode sharp and square? Or is it just starting to nip the end of it?
Referencing your last pic above
If it’s square then it’s sharp.It's square not sharp. I just zoomed in from one of the first pics. What do you mean "starting to nip the end"?
Sorry for the interject, but does that apply to non juiced mills also?When the timing is close to the ragged edge, the first thing to show signs of it, is the electrode. It will melt back the end of the tip.
This has been a pretty educational post thank you all guys for sharing everything y'all have I built my 340 to spray 100 shot on also. Just had health issues get in the way. I've only had one other vehicle with nitrous it was 2100 lb but I didn't set up the spray kit on itIt's square not sharp. I just zoomed in from one of the first pics. What do you mean "starting to nip the end"?
Looks square and sharp to me, compared to a plug before running nitrous and looks the same. I'll definitely be keeping an eye on my plugs as I continue to use nitrous. Seems like the best way to ensure engine is ok. ThanksIf it’s square then it’s sharp.
Compare it to a new plug and give your opinion.
I ain't trying to be a pain in the *** but the inquisitive Carpenter in me wants to know if that's Square from top to bottom or Square from the long side across the short side or does he mean everything involved?Looks square and sharp to me, compared to a plug before running nitrous and looks the same. I'll definitely be keeping an eye on my plugs as I continue to use nitrous. Seems like the best way to ensure engine is ok. Thanks
It can if you have enough compression.Sorry for the interject, but does that apply to non juiced mills also?
I will dial it back another degree of timing and try a colder plug aswell and see if the results change much. Right now I'm at 33* and my best tune was 35* so I may be a little to high. Just didn't want to loose much power when NA but I suppose that's the tradeoff.When the timing is close to the ragged edge, the first thing to show signs of it, is the electrode. It will melt back the end of the tip.
Sounds like I need to buy a book with super large glossy color pictures and get my eyeglasses out and perfect the art of reading plugs just for the heck of itIt can if you have enough compression.
I agree with the fact you want to keep it Full Throttle without the bottle! But the beauty of that is you still got the bottle!I will dial it back another degree of timing and try a colder plug aswell and see if the results change much. Right now I'm at 33* and my best tune was 35* so I may be a little to high. Just didn't want to loose much power when NA but I suppose that's the tradeoff.
Square with sharp corners is good. My advice is above a few posts back. If you were nipping the end of the electrode I’d say pull 3 degrees out of it. But I’d need to see where your fuel is at to know for sure. Youve got a little tune up work left to do. And you’re correct the best (ONLY) way to know what is going on in the chamber is by reading the plug.Looks square and sharp to me, compared to a plug before running nitrous and looks the same. I'll definitely be keeping an eye on my plugs as I continue to use nitrous. Seems like the best way to ensure engine is ok. Thanks
If you get an ignition controller that yanks the timing only when the n2o is activated you can have your cake and eat it too.I will dial it back another degree of timing and try a colder plug aswell and see if the results change much. Right now I'm at 33* and my best tune was 35* so I may be a little to high. Just didn't want to loose much power when NA but I suppose that's the tradeoff.
Not just for the heck of it. You’ll learn a bunch and you junk will never run better.Sounds like I need to buy a book with super large glossy color pictures and get my eyeglasses out and perfect the art of reading plugs just for the heck of it
I'll do another pull or 2 soon with 32* timing instead of 33 and let everyone know the results. For anyone wondering the engine combo it's a 340 bored 30 over with 10.5:1 , j heads, air gap intake, procomp xe268 cam, 780 holley, Doug's headers, msd ignition. Nothing crazy but a fun street car. Thanks again to all the helpful advice.Square with sharp corners is good. My advice is above a few posts back. If you were nipping the end of the electrode I’d say pull 3 degrees out of it. But I’d need to see where your fuel is at to know for sure. You e got a little tune up work left to do. And you’re correct the best (ONLY) way to know what is going on in the chamber is by reading the plplug
What way would you cut it? Just not sure what the correct picture would be. And I'll get more plugs tomorrowCut one of your plugs open and show us where the fuel ring is.
I've considered it for sure. But already bought the msd6a so just waiting for enough funds to rebuy a digital 6plus if loss of power really bothers me haha.If you get an ignition controller that yanks the timing only when the n2o is activated you can have your cake and eat it too.
