- Joined
- Mar 6, 2008
- Messages
- 1,079
- Reaction score
- 737
Looks like I may have connected it a bit wrong after replacing the tank and the FSM is a little unclear. If you have a picture of how they're supposed to be run, let me know.
In your 66 sedan?Looks like I may have connected it a bit wrong after replacing the tank and the FSM is a little unclear. If you have a picture of how they're supposed to be run, let me know.
1942 Supermarine Spitfires don't have trunks
Neither do Thunderbolts, partly because it's full of turbocharger
Op hadn't said what car so 67dart273 was poking a bit at the op to provide the needed info.?????
Well I had the trunk open but no cell phone for a photo. Sorry, I can't help.Correct, this is my 1966 Dart sedan.
I did at one point own a Spitfire, but of the Triumph variety.
THat's a 63 not a 66.As promised. I don't have the clip that goes over the pinch weld on the wheel well installed yet in these pictures. At the top there is a clip similar to the ones that hold the fuel line under the car. You can kinda see it in the first picture
Yes, I stated that earlier. Didn't know if it was the same as a 66, but I posted in case it wasTHat's a 63 not a 66.
Thanks, that's exactly what I needed.As promised. I don't have the clip that goes over the pinch weld on the wheel well installed yet in these pictures. At the top there is a clip similar to the ones that hold the fuel line under the car. You can kinda see it in the first picture
When you have to explain the joke it's really not that funny..Op hadn't said what car so 67dart273 was poking a bit at the op to provide the needed info.
All in good fun!
