Use a table ban saw to hack off the 340 piston crown .
Pm me your address , if you got what I need and I will mail you this R&D piston. Trusting you to mail back the box with my micrometers.
Your to smart 340six..be quiet....unless you have some specifics about scats 4" forged crank . How much does the machinist remove and where, if useing 715 gram rods and bolts and stock TRW Forged flat top pistons weighing??? How deep and wide are the holes....or, hell I would just be satisfied if someone could give me the accurate grams of one of those pistons/is .030" over with rings.
Get get yourself a set of triple beams and start weighing em up, if Ya got em! Otherwise contact to manufacturers and if that's not possible because they're a discontinued piston start a separate post on them hopefully someone will reply with the correct information at this point your info is being buried in here
Junkyardhero got me the specs on my pistons, pins, and rings already.
You got an outside micrometer 4" - 5" you can trade even?
This is what I use to hold pistons I’m grinding on. To get them tightened up properly put a set of Vice grips on the barrel and it gives you more torque (that word excites me) to hold the piston so I won’t move.
I'm still stuck on the fact he wants to trade what he calls a "junk" piston he got for less than $10, for a usable 4-5" outside mic. Yep, even Steven.
No worry's, Walmart has the micrometer for $26.00...and that piston that says R&D might be a collectors item in a few years worth more.
Yep, 26 dollar micrometers from wally world are known for their accuracy. Then again, accuracy isn't exactly your middle name now, is it?
