Did you mean to say exhaust valve?Echoing why I don't use/don't prefer a back cut on the intake valve. Also reiterating the necessity for exh port speed/velocity.
No but I do not and have never used a back cut on the exhaust. Never even tried it. I agree with what he says about tulips as well and would have added that you'd want to specific throat shape for that valve also. I have a lot of experience with stock iron heads and they are limited on the exhaust and what you end up with is going for balance between a good number and port speed/velocity. There's a natural tendency when you get really really good intake numbers to push closer to the ideal exh ratio and that can diminish the velocity/a potential reversion susceptibility with a low lift enhancing backcut if you go by this literature/theory. They don't like to do much over 200 CFM they like to perform in the 175-198/200 range. Casting vary.. but the thing is.. the intakes can flow in the 265-290's cfm quite routinely.Did you mean to say exhaust valve?
Very much so. As an another member says, it’s not all about flow numbers.We collect data when we flow ahead there's different things to look at. That data is very important when choosing a cam.
Why don't you use a back cut on the intake valve and is that for certain applications or across the board?No but I do not and have never used a back cut on the exhaust. Never even tried it. I agree with what he says about tulips as well and would have added that you'd want to specific throat shape for that valve also. I have a lot of experience with stock iron heads and they are limited on the exhaust and what you end up with is going for balance between a good number and port speed/velocity. There's a natural tendency when you get really really good intake numbers to push closer to the ideal exh ratio and that can diminish the velocity/a potential reversion susceptibility with a low lift enhancing backcut if you go by this literature/theory. They don't like to do much over 200 CFM they like to perform in the 175-198/200 range. Casting vary.. but the thing is.. they can flow in the 265-290's cfm quite routinely.
What does the fuel do when it hits the back of the valve with a back cut as opposed to with no back cut. That's a little more interesting to me at the moment because I'm not trying to use the wrong cam timing. We collect data when we flow ahead there's different things to look at. That data is very important when choosing a cam.
Well you guys that think a back-cut on an intake valve totally disagree with Darin Morgan’s thinking. His thinking is it will help in most applications and never hurt. Again I will say this is talking about the intake side.
I think fuel shear and relate it to making more average torque with a sharp lower angle than radiused to the 45 on the intake side as proven by darren Morgan and others. A cousin sister's brother's nephews uncle said he dyno'd and seen 20 foot pounds more average torque once he stopped blending it to the 45 and put a nice sharp lower angle. True story with humor injected.Why don't you use a back cut on the intake valve and is that for certain applications or across the board?
Not sure I fully understand all that but thanks for taking time to explain.I think fuel shear and relate it to making more average torque with a sharp lower angle than radiused to the 45 on the intake side as proven by darren Morgan and others. A cousin sister's brother's nephews uncle said he dyno'd and seen 20 foot pounds more average torque once he stopped blending it to the 45 and put a nice sharp lower angle. True story with humor injected.
what does the sharp angle do with the fuel when it hits it.
Let me take a leap and risk it just being my tunnel vision atm..
Quite possibly a back cut is a compromise with a slight increase in power to offset ..making it acceptable/desirable. Wish I could test
Re animating the fuel.Not sure I fully understand all that but thanks for taking time to explain.
It's the veering off that disguises it as such. Nothing wrong with the discussion as long as it isnt branching too far off into hypotheticals cause then the learning reader gets left behind as it cyclones into what ifs and perspective theoriesToo much is being made of something so basic.![]()
And it was successfully over analyzed, or analized in some posts..Original question why would more low lift flow hurt power, .100 - .200 brought up by the guy at trick flow.
What I got so far is .100-.200 is where both valves are open during overlap and don't want the intake easily overcome to reversion.
Yep. Kind of what I like about rollers, they don't hang around below max lift very longPlus, why do you want the valve hanging around those low lift? It makes no sense.
No matter how great your flow is at .200 it better damn well be better at .500 and .600 and .700. Why leave the valve there.
Valve speed is horsepower if you control the valve train.
Bingo, but not to large in pipe size.If you got a full exhaust would ideally want zero back pressure.
The only time I have ever heard of a slower valve opening being used for a in serious N02 and high PSI supercharging.nothing like losing inertia trying to push slow exhaust column out.
"Don't youuu..forget about.." scavenge.
I'm going to devote an entire chapter to Intake Valve Opening (IVO) in my book on The Theory and Application of Racing Cam Design.
I consider the IVO and the EVO to be of equal importance, but EVO occurs first.
However, the most important degree in a camshaft is the degree BEFORE the Intake Valve Opening. If you could measure the cylinder conditions at this point, it would tell you how much exhaust gas is left in the cylinder to be pumped out, and what the residual pressure is. These 2 factors determine what reversion you will have when the intake valve opens, and how badly that will hinder cylinder filling on the intake stroke.
You can demonstrate this easily by getting 2 cams ground with identical intake and exhaust profiles, but on 2 different LSAs, say 106 and 108.
Install each cam in the engine on the identical INTAKE centerline. The only different is in the position of the exhaust cam, the intakes having identical opening and closing numbers.
These cams will demonstrate 2 different power curves, with emphasis at different RPMs. All caused by the effect of more or less reversion on the same intake lobe.
Any cam design that opens late had BETTER open fast, or it will develop insufficient area after TDC, and not fill properly.
I have done it this way since January, 1977, as it seems to deliver good results.......
There is a lot more to be said, but I'll wait for later.
