HELP Identifying Rear Qtr Panels for Convertible '68 Barracuda
Mopar Virgin
Trout Lake, WA
Hi All ... My build project is moving along while my bank account shrinks. Paint is done and needing help sourcing rear qtr panels. One of our members was gracious enough to pull ones he had in storage out (see pictures). The aftermarket ones are designed for convertible Darts and "can work" but are not apparently a proper fit, per Laysons and ClassicIndustries fitment notes.
So, the other member and I are not clear what the real difference is or if that matters. Hoping one of his 3 pair is for a Bcuda and that someone out there can look and verify?
@jaws
My understanding is the barracuda is curved at the top edge vs more sharp.
Look at the doors top edge it should follow that line
Not the real curve just for clarity of example
It is the top of the panel that hugs the quarter panel that is different, you don't show that area well with the pictures you posted. The Dart is more straight while the Barracuda has a bulge and is more round, hard to explain...
Here is a long shot down the DART rear seat arm rest panel and the door.
Barracuda should be similar but rounded vs sharp
The arm rest should follow the shape of the door
In this pic you can see the passengers side rear panel. Notice how it is flared up just a bit at the rear where it meets the top. The Dart panels are straight there. It is hard to tell in your pics but it looks like those may be for a Dart
I think I see what you are speaking about ... So in you opinion, will Dart panels work or will it be a significant visual "thing" I'd be obsessing over for years? Also, looks like you did a great classy detail on yours. Could you send me a close-up of that and let me know if it's simply painted, or covered, or what you did there?
I’ll go out to the garage later today and I should be able to come up with the part numbers for the rear panels for the Darts and Barracudas. You can then just the list with the part number that’s molded into the backside of the panels.
I wish I could say I did something creative there but that is just the way they were originally
The best that I could come up with is that the replacement part numbers listed below. With that said the replacement panels would have had to be painted before they could be installed. That means that the replacement panels may not have the same part number as the production parts had.
1969 Barracuda 2090 right 2091 left
1969 Dart 2092 right 2093 left
I don’t fully understand why the part numbers are only four digits long.
In 67 it appears that the Dart may have used a two piece panel and the Barracuda used a one piece panel.
I couldn’t figure out what was used by part number on either 67 or 68.
67 dart the plastic panel is all one piece.
There is a chrome metal piece that attached to it but I think barracuda has the same.
67 dart origionals
They were the same in all my 67-69 Darts though some were two-tone. Never had a 67-68 Barracuda convertible, but my 69 looks similar to my Dart except the tops...
