vallianted
Hey all.what's the biggest tire I can put on the back of my 65 Valliant.I have stock ralleys 14 by 6 with a 4 inch bs.
Ted
Ted
You can find hi-po 15’s but they are very low profile and too short for an a body unless you are doing auto-x.I have run a 235/60 x 14 tire on the back of my 65 Barracuda, and it did fit, but I agree with the Professor that a 235 is a tad wide for a stock 14 inch ralley wheel (really 14 x 5.5, not 14 x 6). Still, I never had any problem with that setup except when I had a couple of passengers in the back seat and then it would rub slightly on turns.
Now run 15 x 7 SBP Cragars with 225/60 R 15s. They have more offset and actually fit better than the 14 inch ralleys.
But even 15 inchers don't give you much of a selection of genuine high performance tires these days.
Mopar Action's Green Brick ran the same 225/50VR15's My '88 ShelbyZ came with when it placed 3rd in the One Lap of America, and it's the size I have on My '64 GT on Popo Rallyes at the moment, they are low & some may not like the look.....but a little free gearing bump if You have a dog rear gear.You can find hi-po 15’s but they are very low profile and too short for an a body unless you are doing auto-x.
https://www.tirerack.com/tires/toyo-proxes-r888r
Pics!!!Mopar Action's Green Brick ran the same 225/50VR15's My '88 ShelbyZ came with when it placed 3rd in the One Lap of America, and it's the size I have on My '64 GT on Popo Rallyes at the moment, they are low & some may not like the look.....but a little free gearing bump if You have a dog rear gear....
I want to see your 64 with the lo pros on it
Only pic I have of My ratty in progress ride is on stands, with the rear axle jacked up to see how it sat w/the -2" 6-leaf ESPO's I just put on, maybe 5+ yrs. back.I want to see your 64 with the lo pros on it
I know your painOnly pic I have of My ratty in progress ride is on stands, with the rear axle jacked up to see how it sat w/the -2" 6-leaf ESPO's I just put on, maybe 5+ yrs. back.
I like it!
I think Darts and Valiants will take the same sized wheels and tires. (Measure first) The black wheels on my 66 are 15x7's with a 4.25" backspace. 225/70-15 tires. The Halibrand clones are 15x7's with a 4" backspace (I believe,never measured them) with a 235/70-15 tire. No spring or wheel lip rubbing with either but there is a slight wheel house rub with the 235's occasionally. Not an issue though.Hey all.what's the biggest tire I can put on the back of my 65 Valliant.I have stock ralleys 14 by 6 with a 4 inch bs.
Ted
You can, I did.I have 235/45r17's on my 66 pretty sure I could sneak a 245 on it.
