I think by 64 they were standard in all cars.. in Michigan they were mandated in 65 and newer... you can actually not have seatbelts here if you are before '65.. i won't drive 50 feet without a seatbelt though.. seen some bad **** when i towed cars..Know what I am not sure if the Cuda has them or not?
Been a while since I took it apart.I think by 64 they were standard in all cars.. in Michigan they were mandated in 65 and newer... you can actually not have seatbelts here if you are before '65.. i won't drive 50 feet without a seatbelt though.. seen some bad **** when i towed cars..
Yeah.. i didn't even think bout it before i put my dynamat and carpet in of course.... king of doing **** 3 timesBeen a while since I took it apart.
Pretty sure they’re a 1/2 fine thread pitch. I used 4x4 inch, 3/16th thick plate on my dart.So.. i need to make seat belt mounts for my car as it didn't come with any... i see guys using just a bolt and big washers.. but i was thinking of doing like a 4x4" plate with holes in it and plug welding it to the underside of the floor.. am i overthinking? also.. what bolts do seat belts use 7/16-20? Also.. need to find some gray seatbelts![]()
3/16 you are a madman... i'm going 1/8Pretty sure they’re a 1/2 fine thread pitch. I used 4x4 inch, 3/16th thick plate on my dart.
I’ve been working on touching
yeah that's the planI think they welded a nut under them also?
Yep, and a good morning to you this fine day bud..All caught up. Good am
It’s what I had handy after making brackets for my rear watts link3/16 you are a madman... i'm going 1/8
That's plenty. As I recall, I repaired one in the wheelwell and don't think they were even that. You'd rip it out of the surrounding sheet metal before you would damage that. As for the bolt, I'm not sure of the thread size, but they look bigger cause they are shoulder bolts and have an oversized hex head. There are different lengths for different positions. I think the ones in the center hump were longest cause they sit down in.3/16 you are a madman... i'm going 1/8
Think about it this way, The outboard belts were singles. The inboard belts were doubles (with the center belts) so you need a longer bolt.I think the ones in the center hump were longest cause they sit down in.
Yes, but on mine I'm pretty sure it was more than just the length for double belt.Think about it this way, The outboard belts were singles. The inboard belts were doubles (with the center belts) so you need a longer bolt.
Once the modules power down the only thing that should draw are the clock and radio anti theft I would think. That's a head scratcher. Like you said, .2 should take a battery down in 4 hours. Bad cell? Do you have a electronic battery tester or a carbon pile tester. I like the old carbon pile testers, load them up good and watch the cells for bubbles.Found no significant draw in the Avalanche. 0.2 amp, not enough to take a battery down in 4 hours. Unless its a constant thing, its hard to find. I have a feeling it will go away as weather warms up. But, the ecm was warmer than surrounding components, using my flir camera. Im baffled. Time to move on to less important things.
New battery. I figured old one was junk, it probably wasnt.Once the modules power down the only thing that should draw are the clock and radio anti theft I would think. That's a head scratcher. Like you said, .2 should take a battery down in 4 hours. Bad cell? Do you have a electronic battery tester or a carbon pile tester. I like the old carbon pile testers, load them up good and watch the cells for bubbles.
I'm sure it looks spectacular.View attachment 1716229955Good morning all. Rainy here. I have one more day off from work. I’ve been working on touching up the paint on the dash of the dart.
