Radio suppression. I don't think they make them any more and if they did they would be junk.
Vans had some at one point.Radio suppression. I don't think they make them any more and if they did they would be junk.
Know a guy that did. PITA... leaked constantlyAnyone ever dug their own pond?
Yep. Like digging my grave..Vans had some at one point.
How big and how deepAnyone ever dug their own pond?
That's a lake in these partsWhat size are you thinking? One I mentioned was a about 300 yards in diameter... maybe 12 feet deep in the center. Dammed up a small valley with an earthen damn and clay lined the basin. Ran an aerator so the water wouldn't algae out and die
That's a lake in these parts![]()
About a days work I figure. Easy with the dash out.Dang Wolfie that's pretty hairy wiring, like your new block idea
If you're building a harness dash out's the way to do it!About a days work I figure. Easy with the dash out.
Mine is only 4 and a half ft deep with a few levels and an alcove for the fish to hide from about 14ft round. I used all the dirt and a bunch of rocks to make a waterfall..True
Well... I go by the rule of thumb being that if it's being fed by a stream or river.. it's a lake. If it's runoff or spring without an outlet, then pond
Yep no dash no column , he'll no windshield.If you're building a harness dash out's the way to do it!
Just need a good liner.
So I have a small pond already. Maybe 1/4 acre ish. Not really sure how deep but it’s fed by a natural spring. I don’t think it’s too deep but no pond vegetation and it never has algae. It’s also rather lifeless as far as we can tell. I can see down about a foot, then it gets murky and can’t see. It’s the only natural water around here that I can honestly say I’ve never seen dry out even in the droughts to where I can see bottom. It’s full right now of fallen trees and I’m gonna clean it out. Trying to decide if I want to drain the thing into the creek on the one side and then backfill it and let it fill back up. I don’t want to risk destroying the natural hard pan.What size are you thinking? One I mentioned was a about 300 yards in diameter... maybe 12 feet deep in the center. Dammed up a small valley with an earthen damn and clay lined the basin. Ran an aerator so the water wouldn't algae out and die
looks nice in the photo but see if you can find something that protects the connections, and supports the bundled cable. I've seen a few posted here in the past. (here=FABO not coffee thread specificly)I think I will just get one of these and make a harness.
Ya got the ice cubes, close enough lol!You might be a redneck if? I had a hankering for wine and Jodi is not home. She generally has a white chilling, and we were out of red! Improvise, adapt and overcome! Chardonnay on the rocks!
But I walked it today for the first time in years. It’s not easy to walk around due to terrain. But it’s at max depth now as it’s up to what appears to be its natural overflow relief point. Thinking of daming that overflow and seeing if I can get the water level to raise. I’d like to drop in aerator in and eventually stock it with blue gills
Yes....Why?Anyone ever dug their own pond?
I'd go with an agricultural irrigation pump to draw it down before I'd modify any of the containment.
