That picture was taken right after she came down from the jackstands, so the front suspension hadn't settled.
This picture looks like positive camber too.
If you're okay with it, that is fine but it is terrible for handling and stability.
i saw that and i really hope it's lens distortion or angle of the shot... otherwise something is, uh... not right.This picture looks like positive camber too.
Good info.. I actually made the stock A body cables work, pretty easily. In hindsight, I probably could've left the springs uncut but they work fine.Quick specs for those considering the swap. With the aluminum diff cover and cut down 8.8 the fluid capacity is right at 2.5 quarts. If you are going 7290 driveshaft to 1330 rear, Spicer 5-7437X is the U-joint your looking for. The Driver side Explorer Parking Brake cable is almost the perfect length for the passenger side of an A-body. Oh, and with your springs offset 5.29 backspace is about perfect for me.
It certainly did not have positive camber when I aligned it, but I have been meaning to bring it into work and double check. I have another project with low miles and the alignment changed quite a bit while sitting. Do poly bushings "settle"? It feels pretty stable at 75-80mph though!This picture looks like positive camber too.
Spicer 457C is the U joint that should work to hook up the ford yoke to the chrysler driveshaftJust a conversion u-joint from dodge drive shaft to ford yoke. I have a 8" in the dart now and I'm kinda hopin it might work, but I havn't measured yet. It's a conversion u joint. If it dosen't I'll just get the measument's and go look in the spicer book.
Jake
I tried coming up with a pinion snubber that would work off the mounting flange where the pinion on the 8.8 is. Nothing I came up with I was satisfied with. I just bought a set of Lakewood traction bars. I plan on painting them black.I got a 8.8 out of a 97 exploder this last week. It came with disc brakes, limited slip, 3.73 gears, complete driveshaft, u-bolts and brakets all for $150. I'm going to shorten the long side axle tube and center up the rear-end. That will bring the rear within an inch of the factory A-body rear. It will also let me use an extra short side axle shaft, so no custom axles. If your wondering why not get a 8 3/4 well I plan on doing the whole swap for around $200. You couldn't hardly get a bare A-body housing for that much!
Here's a few pictures. I'll post more as I go along. I'm going to move the rear springs into the frame when I do the swap also.
Jake
I got most of the info to do this swap from this site, so thanks to everyone who's posted about this in the past!
I bought new shock plates. Reused the 8.8 u bolts I believe, and shorten the drive shaft that originally was a slant six/904 drive shaft.Questions for the group as I am getting ready to do this on my 73 dart 4 door:
Has anyone used these shock plates with the proper 3.25" U bolts? I am unsure if they will work with the 3 5/8 holt spacing...
Leaf Spring Lower Shock Mounting Plate Kit
likewise, what about these others, they seem like they would work without modifications...
Pardon Our Interruption...
Finally, did anyone that used their old 7 1/4 and a904 driveshaft have to cut the driveshaft down in addition to adding the spicer adapter and u joint, or did the original length work out?
Thanks in advance!
-Frank
Hey guys. so went through a few pages of this, watched a few youtube videos but i hear different answers. sorry if i looked over it anywhere in this thread but ive heard both that you have to narrow and you dont have to for a 8.8 into a 72 duster. it seems like the 72 is kinda the bastard year for some things. either way its my favorite. ive been trying to find a 8 3/4 in my area but can only find B C and E ones mostly. have not found a A body one. so thats why im kinda leaning towards a 8.8
With mini tub and relocated springs, 18x11’s will definitely fit in the tubs, it’ll just depend on backspacing and axle length.well ill be mini tubing it and moving the springs inboard. i was planning on trying to run 18" demon style wheels. although i can only find them in 18x11" which i dont think will fit. there is a pretty reputable shop by me that can narrow them.
im horrible with wheel specs. i usually just buy something and hope they fit or make them fit.
well crap if thats the case i might have to shorten the diff if needed. just gotta pick up a diff then.With mini tub and relocated springs, 18x11’s will definitely fit in the tubs, it’ll just depend on backspacing and axle length.
What’s the backspacing on those 18x11’s?well crap if thats the case i might have to shorten the diff if needed. just gotta pick up a diff then.
