carfreak6970
So the car in question is a 70 charger. It has 10" drums all around that were rebuilt with new springs and cylinders a couple years about (about 1500 miles ago), new hard and soft lines, new master cylinder, with a repro disk brake booster. I bled all the air out of the lines and verified that there are no leaks in the system. However my issue is under heavy braking I can not get the wheels to lock up (from a 10-15mph roll). So the pedal does not go to the floor, but it does stop before it gets to the floor, it is solid.
so here are a couple ideas I have that may be the reason for my subpar braking:
So the car was always a power brake car so I don't believe there is an issue with the brake pedal length, but to be sure is there a way to determine if I have the correct power brake pedal?
This is the second brake booster on this car. I adjusted the push rod length that protrudes into the master cylinder. I believe I left about a .015" gap between the tip of the push rod and the corresponding cup in the master cylinder. Is that too much or not enough? I thought it was enough from what I found online. Like stated above, the brake pedal is solid but could it be that the master cylinder/booster doesn't have enough travel?
I did feel the wheels after the test drive and they did feel like they were really warm? could it be that the push rod is to far extended into the master cylinder to the point the brakes are dragging and they are getting hot to the power that they are losing their effectiveness?
The last idea I got was maybe the adjusters are not locking into place due to that lever not contacting the star part of the adjusters. So after a couple stops the adjusters work themselves in? I did go in reverse a couple times and slam on the brakes (which I thought was a way to help adjust the brakes out?) and it did seem to improve the braking, but it was at the end of my drive and didn't get to test anything further.
Am I on the right track? is there ways I could prove if any one of these ideas is causing the problem of lack luster braking?
thank you
thank you
