Indy 360-1 Cylinder heads on small block LA's
yeah, that´s true. They drilled the threads for the water neck too deep, directly into the water passage....not a huge problem, but not what i would expect also. Oh, i´ll work around as usual ;-)
some progress.....
Could not resist to put the intake on to see how tall this is....for sure i have to cut my velocity stack (Hood´s got a hole in it, six pack scoop).
It´s coming together.....i´ll try to have it running until saturday...one week until T&T :)
Cold Lash is set to .002", we´ll see if this works (SR on HR Cam). Everything fits under the scoop, the stack needs to be shortened.
I wish I had ordered 360-1's last year before the huge price increase. Looking forward to seeing how it runs.
here we go.....don´t really know if it sounds different than before....thinking it sounds a little more agressive. Next week Test&Tune....wish me luck!
good morning, back from a weekend at the track. We had decent weather, not the best conditions but at least dry. Track was good.
Engine / Car ran good, it feels definively stronger in the upper rpm range - pulls to 7000 hard. I got 5 runs with the first ones all over the place, had to adjust to the new combination a little. Got a new PB (10.44), a new best top speed (129 mph) and a new best 60ft. (1.47s). All of that in different runs. Unfortunately the newly installed steering box gave up with a lot of play, input shaft moves in and out....car was no longer safe to drive. I´m pretty sure a 10.3 would have been possible with more rpm in the first two gears.
so all in all the old standard port setup wasn´t that bad. considering the cost i´d probably would have done better with a set of Bloomer SB Heads. I´ll get the steering issue fixed and will get more track time - unfortunately due to work schedule not this summer....earliest end of the season. I think another cam change is necessary to get more gain out of the cylinder heads - we´ll see what i come up with ;-)
Michael
Michael
You had fun and didn't break anything, so it was a good outing. What were your 1/8 mile numbers?
yeah, you´re right. The 1/8 mile numbers are 6.612 @ 104 mph, before it was 6.661 @ 103 mph. I do run a sniper, have to check the logs what´s going on AFR-wise.
Exactly what I’d expect to see from installing larger heads.
Sometimes it can even come with TQ penalty in the lower rpm range.
Do you have weather data for both runs that could be used to correct them to standard sea level conditions?
Hi Dwayne, no unfortunately not. I´m pretty sure the weather now was not as good as back in fall of 2023 when it ran the previous best. It seems i had too big expectations, have to tune the new combination to reach full potential.
For some reason I thought you bought the 360-2cnc230’s…….but from the pics they look like the cnc’d -1’s.
So you got the 245’s?
What were the old heads…… Ede’s?
old heads were cnc´d procomps. New heads are 360-1´s as cast, not cnc-ported. They were then hand ported by a good guy i trust, i wanted it this way because i had concerns regarding them leaking as many do with the big cnc port.
here we go.
old heads (Lift / Flow I/E) .100 68 65 .200 144 112 .300 213 156 .400 258 194 .500 282 216 .600 294 218 .700 300 220
new heads (Lift / Flow I/E) .100 70 53 .200 144 110 .300 206 150 .400 260 182 .500 296 206 .600 316 224 .700 324 232
directly compared the new heads intake numbers are better from .400" Lift and up, the exhaust numbers are not as good as with the procomps. At the moment i run a cam that´s 250/250 @ .050", i think some split (more exhaust duration) would help the situation. I have sth. in my mind.....as always, still learning as i go.
Michael
here we go.
Michael
Boy I know it’s more work but some of you guys are sure lazy posting flow numbers. That looks like my grandmother’s Scramble board.
