Dash board switch
Wolfgange
tucson az
Hi I have a stock wiring system in my 69 valiant 100 /6 Question can i use a 1970 to 72 valiant dash panel?? Will all my stock wiring plug into the back of a 70/72 plymouth A body dash?????
Go to MyMopar.com, download the 69 and 70 service manuals, and compare them. Where is your horn relay? At some point they moved the relay from under the hood to inside the car
The BIG issue is, the 70 dash has no place for an ignition switch, if you are talking about the complete dash
Not without modification.
