That's what I just was about to askThose are real learning moments.
Any day you learn something is a good day.One of the downsides of doing a lot of testing are those, “well……..that didn’t work” moments.
When something you were pretty sure was going to be great……..wasn’t.
I'm just here for the comments!
Worth it for the entertainment value alone!
The only thing I would have liked to see done differently with the competition would be for it to have been been done on a solid roller platform, but I can also understand why that probably woudn't be feasible for that many tests as well.If you cant tune it then its a pointless test. Different cams create different intake and exhaust events that take place. Any change will change the residual gas species left in the cylinder requiring a different tune to account for the increase or decrease in CO left in the chamber. If you under or over scavenge the chamber it needs a different tune.Everyone generally says get a custom cam, but now all a sudden it's guessing and a pointless test,
There’s a video on the NK Performance Facebook page where the winner discusses some thoughts on coming up with the winning cam.
Blah, blah, blah...If you cant tune it then its a pointless test. Different cams create different intake and exhaust events that take place. Any change will change the residual gas species left in the cylinder requiring a different tune to account for the increase or decrease in CO left in the chamber. If you under or over scavenge the chamber it needs a different tune.
Different engine combinations create different vacuum profiles that need to be tuned for. There are way more variables that a list of mechanical parts. Its how those parts affect the chemistry of the burn that needs to be addressed.
Does it need more fuel or less fuel does it need more timing or less timing to place the PPP at the correct and most advantageous crank angle. If one camshaft creates a leaner intake fill then the timing needs to be altered to get the burn started at the right time.
Apparently the guy that won used streetable lobe profile also.DV also said his lobe profile was street car designed lobe, other competitors could be super aggressive and not live long on the street, straining your valve train.
But Vizard's built Pinto motors.He tested 18 plus cams and won. That’s what testing does for you.
Wasn't everyone free to do testing beforehand?Over on Speed Talk there was some discussion about whether familiarity with the platform was an advantage or not, with people arguing on either side of that.
Myself, I think having done testing on a given platform is an advantage over just looking at the engine specs.
They could if they wanted too.Wasn't everyone free to do testing beforehand?
I say Definitely, if your mainly an LS builder especially around that power level your gonna have an advantage over someone that doesn't.Over on Speed Talk there was some discussion about whether familiarity with the platform was an advantage or not, with people arguing on either side of that.
as you with Ma Mopar.he got to see the trends…..of that platform.
But DV is the godly guru. He should have been on the top of the heap. He let a kid beat his ***.They could if they wanted too.
I don't think the winner did testing just for this competition, he just has in the past dyno a bunch of cam plus he works at cam motion so he has at lot to draw from.
You can see it in the results when he said he went large on exhaust for hp and mild on intake for torque, cause most didn't go with that wide of a split like he did 238/259 108.5 and the ones that didn't but did well seem to make it up with wider LSA and or ICL.
And you know what those numbers remind me of? The Whiplash/Thumpr and one of Crower's early lines....I forget what they called it. Comp also had their DEH grinds that were similar. But all four of those examples have WIDE duration splits and narrow LSA. That's why those cams can actually work well if everything matches up.You can see it in the results when he said he went large on exhaust for hp and mild on intake for torque, cause most didn't go with that wide of a split like he did 238/259 108.5 and the ones that didn't but did well seem to make it up with wider LSA and or ICL.
and here's the part where that house of cards all falls down. DV tested over 19,000 cams he should have an innate advantage on that alone. he's done dyno testing, he knew the parameters, he writes the theory; advantage, advantage, advantage.I say Definitely, if your mainly an LS builder especially around that power level your gonna have an advantage over someone that doesn't.
The 25 year old janitor at that.and here's the part where that house of cards all falls down. DV tested over 19,000 cams he should have an innate advantage on that alone. he's done dyno testing, he knew the parameters, he writes the theory; advantage, advantage, advantage.
yet here we are.
it's like the janitor comes in and solves the unsolvable equation on the chalkboard that the PhD professor put up there.
