Walker “Sound FX” vs “Quiet Flow 3” mufflers
rumblefish360
I have escaped the EVIL Empire State!
Florida
Has anybody have real world experience between these two mufflers on which is actually the quietest muffler?
Performance is not part of the criteria only silence.
No interior sound, as little sound as possible at the exhaust tip is sought.
Thanks
One is advertising "sounds, the other is touting "quiet".
I would guess the quiet flow would be quieter.
I do NOT know that as fact, however.
Is one triple pass and the other straight thru?? Choose triple pass.
Extending the tail pipes will remove the noise from in the car.
I prefer to use walkers mufflers. The quiet flows are made better and are more effective. Use the biggest case that will fit the space. The soundfx are not straight through.
There are also tail pipe inserts that can be bought or made.
Just because I'm curious, is this a sleeper thing or do you just genuinely want a quieter car? I did a cam swap on my Viper a while back and have never been able to quiet it down since. Just not a lot of market for quiet with those cars, especially when you need 3" exhaust to go with it. Not a commonly searched set of terms it seems, lol.
Have used the FX-Sound mufflers on my Dual Exhaust 2" pipe system.
They are just basically a cheep tin can, don't muffle the sound very well. Too loud for my liking.
I ended up putting Resonators in the tailpipes at the rear bumper. That quieted it down nicely. Could still here it was a V8 when you got to it.
Mopar set them up that way with the resonators at the rear.
I used the quiet flows on my Barracuda . They dumped just before the rearend under the car. Not totally quiet but got rid of all the drone from the flow max I tried first.
Want it quiet, and still performs well?
Get the right size tubing thru the muffler for the engine combo...... then get the biggest, longest, fattest, thickest muffler that will fit under the car.
I put a QuietFlow on my truck, it was............wait for it.............quiet. I like them and will be using them on other cars as they come up for exhaust upgrades.
These Walkers, are the two I’m up for and FWIW, I also recommend the longest muffler that can fit for quite.
True, not a common search for quite.
I want a quiet ride. This is for a low compression 318-2bbl/727-2.94 geared Cruiser.
Are you currently in Florida with the mufflers?
Excellent!! Thanks
Performance is not sought. I wrote it above.
This is mostly the problem with mufflers getting smaller inside the muffler. The exhaust pipe is 2 inches. Most mufflers neck down to 1-7/8 or so. This is not an issue with the low compression 318z
After that, I have always echoed what you wrote. Works like a charm.
Excellent!!! Thanks!!!
What size pipe? 2.5? If so, send me a PM.
2 inch pipes. Thanks. I’ll pass.
FWIW, the car is a ‘66 Charger w/a 318-2 bbl poly, 727 & 2.84 gears on stock tires.
I am trying to get and have a line on a 2bbl intake as currently it’s a 600 cfm 4bbl Competition series Carter on a factory 4bbl. intake.
I just want to return it to stock.
Excellent!! Thanks
Still in MN yet, sold the truck with the FX-Sound dual exhaust and resonators.
I have the Stock single 2 1/2" exhaust system on the '89 318 D100 that is in FL now. I like the sound of that one and no resonators, tailpipe exists behind passenger rear wheel. It is quiet, I like the tone of it, it wakes up when the 4 bbl opens up. Win, Win !
Ahh good thing you guys aren't buying and selling mufflers on this thread. I thought for a second that this was a parts wanted thread. I must be mistaken. :BangHead: :rofl:
Yep! Just research! Just looking for an actual “QUITE!” muffler. This car is a cruiser and mostly stock. The 4bbl intake is a stock part but not what came with the car.
The previous owner additionally put Cherry Bomb glass packs on the car 30 years ago. Personally, I can’t stand the sound of these things. They are not my bag. An open straight pipe sounds better.
I know these aren't what you mentioned, but I have had a pair of Hooker Aerochamber mufflers on my 340 Dart for 10+ years. They are what I consider quiet. 2.5" pipes and muffs, TTI H pipe system and headers.
My favorite muffler to use on the hotter mills I run in the streets.
They are NOT what I’m inquiring about and not nearly the style or sound level even considered.
I like the Dynomax turbos for upgraded kind of engines.
Hooker Aero Chambers for the hot street strip ride.
Hooker Max Flow or the equal for the race car. Screw sound control! Muha ha ha ha ha….
Also as a FWIW, I thought d try a different brand and try ordered up AP mufflers at 2-1/4 inch. That will let them slip right in on the system. 19 inch case. Getting more under the car with the existing system isn’t an easy to do though there is a few more inches of possible muffler fitment available.
Sound clip to come after the work is done.
