plumkrazee70
I got this motor from a friend. It's an 85 318 from a Chrysler 5th ave. He had a video of it running before he pulled it. Its pretty grody.
I disassembled the entire thing and here is my plan.
Replace:
All block plugs
Timing chain
Oil pump
Gaskets
Heads (two sets to choose from) one has 2.02 valves have to check the other. Probably need them checked before use.
Used set of Exh manifolds
Reuse:
Camshaft
Lifters
Pistons (standard)
Rings
Questionable?
Cam bearings
Main bearings
Rod bearings
I just want a running motor for our 69 barracuda, nothing crazy, just need to get it on the road so our family can enjoy it. My boys are 10 and 12. I'm not interested in doing anything crazy (why I'm reusing what we got).
Attached are the pictures of what I have so far. I'm debating on having th block hot tanked or just taking it to a do it yourself car wash to clean it up.
I'm following @RustyRatRod lead like he did on his s6.
Thoughts and comments welcome, but remember unless it's glaring and needs replacing, I'm trying to do this cheap or with parts I already have, so please don't spend my money (I know it's easy to do lol.)
Replace:
All block plugs
Timing chain
Oil pump
Gaskets
Reuse:
Camshaft
Lifters
Pistons (standard)
Rings
Questionable?
Cam bearings
Main bearings
Rod bearings
