B3422w5
No they have 2.08 Int valves and fully cnc ported. Flow numbers posted if you read back in this thread.
Oh, cool deal!
https://www.compcams.com/oval-track-drag-race-263-270-solid-roller-cam-for-chrysler-273-360.html
i think your current cam is to big already. the cams that you posted are very close to the cam in my 414 W8 and there is no way a Trick Flow head will compare to a W8.
B3422W5 has a 565 lift cam and runs 10.20's if i remember correctly and close to your race weight.
sometimes less is more.
That cam should work very well in a 408 with those flow numbers and over 12:1.
I wasn’t comparing W8 to TF, all I was saying is his heads won’t take advantage of a 670-700 lift camshaft.While I agree, I do t think he has any illusions of W8 performance. IMO, the search here is for a better cam than he has with taking advantage of the ports capabilities. Once the overlap and power band are found for his combination he’ll be in good shape.
That’s true
With flow gains thru .700 lift, I’m not seeing any issues with the lifts for the recommended cams.
Not to mention that with the less than ideal 59* lifter bank angle, plus what you lose in the lash, those cams would be lucky to see a net actual .650” valve lift.
Car weight is 3450 with me. Remember I came here looking for recommendations and gave my current specs. I’m not saying I need a cam with more lift, but this is the infor reputable cam companies are giving me. This is why I’m having a hard time picking a cam. Conflicting info from everyone. I believe I could use more duration and maybe a different LSA.10.40 at 3350 lbs is roughly 530 HP. with that big of a solid roller cam, heads that flow 320 cfm...... 620+ HP and it's not even close to that.
i just don't see what you guys are seeing or thinking it will do with a bigger cam.
It's unlikely everyone is gonna agree.Car weight is 3450 with me. Remember I came here looking for recommendations and gave my current specs. I’m not saying I need a cam with more lift, but this is the infor reputable cam companies are giving me. This is why I’m having a hard time picking a cam. Conflicting info from everyone. I believe I could use more duration and maybe a different LSA.
it's a tough decision to make.Car weight is 3450 with me. Remember I came here looking for recommendations and gave my current specs. I’m not saying I need a cam with more lift, but this is the infor reputable cam companies are giving me. This is why I’m having a hard time picking a cam. Conflicting info from everyone. I believe I could use more duration and maybe a different LSA.
1 to 2 tenthsYou’d never know which is “best” without trying them all.
Just buy from a place you trust, and hope it works out to your satisfaction.
Just remember, this is something you “want”…….. the motor doesn’t “need” a new cam.
Let me ask you, in terms of just the cam swap, how much ET gain would you have to see to feel it was worth it?
He might be into it after the cam change.i would try a different converter before anything else.
I checked PTV clearance at TDC, +/- 10 and 20 degrees. I am working with bullet. I don’t want to go larger than my current lift which is 660. Duration I think something around 268/274 with a 108 LSA should be close.One thing that hasn’t been brought up yet, which should be checked when adding as much duration as being discussed here, is……..before ordering a new cam……. Check to see what the V/P clearance is with the current cam.
With the data for the current cams LSA and intake C/L, along with the lobe lift at TDC, and the measured clearance……… the clearance for the new cam can be reasonably estimated.
If the current cam has tons of clearance(.150”+), then there shouldn’t be any issues with cams in the duration range being discussed.
But if the clearance is in the .100” range, you may not be able to add as much duration as desired.
Would love to know compression, stall and shift RPM’s as I have a very similar grind from Comp that I’ll be running in a Victor headed 420”, 2800 lb duster (if/when I get my car back from bodyshop jailI do agree that you do need more duration.
The bullet cam would be the one I would pick out of the ones you listed.
This is the cam that’s in my 414”.
That should run very very good!Would love to know compression, stall and shift RPM’s as I have a very similar grind from Comp that I’ll be running in a Victor headed 420”, 2800 lb duster (if/when I get my car back from bodyshop jail)
Hoping so!!! Bit of a penalty up here in Denver, but we’re all slower together I guess.That should run very very good!
So as not to derail the thread, do you have any links to your build? I’ve been recently curious about the victor head option.Would love to know compression, stall and shift RPM’s as I have a very similar grind from Comp that I’ll be running in a Victor headed 420”, 2800 lb duster (if/when I get my car back from bodyshop jail)
No build thread for the motor yet as I’m waiting for the car before putting a motor together to just sit on a stand, but can’t wait to start it!!!So as not to derail the thread, do you have any links to your build? I’ve been recently curious about the victor head option.
16.4 compression, 6400 stall, 7800 shift rpm.Would love to know compression, stall and shift RPM’s as I have a very similar grind from Comp that I’ll be running in a Victor headed 420”, 2800 lb duster (if/when I get my car back from bodyshop jail)
