Alternator Field Locations
VAD Gold Rush
Oklahoma
I'm wiring my 1974 Valiant completely from scratch. The car has the standard 70s 60amp alternator on it. Do any of you know which plug is field + and which one is field -?
If 70’s style either one is the same.
Earlier ones are one is grounded and one is +. It’s all in which voltage regulator you are using.
Ohm meter the tab (spade connector to brush) to alternator housing. If one is open (+) and one is 0.00 then that one is ground.
The two field connections are electrically interchangeable. There is no pos or neg for the field.
