340 manifold heat shields now available at Mancini's!
Professor Fate
Push the button, Max...
Wisconsin
And they're not totally obscenely priced, either.
Probably should buy a set or two in case they sell out the initial run and decide not to make another run.
Looks good! Sometimes ya do what you gotta do.
I hope you rounded off those corners, though- knowing me I'd need stitches soon enough if I didn't! :)
Well I wish I did but was too anxious to get it mounted. Only got cut up making it before I had a chance.
How well do the boots work on their own?
I'm running those manifolds with no heat shields and the boots on my wires are still like new. i used msd wires with vari angle boots though. also have the wires run different then the other guys here so they are more away from the manifolds.
I initially tried ceramic boots but had interference issue. Glad you found a fix.
My 340 dart ran around for decades without these and never had an issue. Unless you’re 100 point restoring..why bother.
If u want exhaust headers and manifolds to be a cut above jet-hot coatings is a really good solution. Never rust or discolor plus the thermal factor. My headers have it. Eventually I hope to send them my exhaust manifolds.
Nice homade shields. Mind if I copy?
Everything's costly some stuff we afford some stuff we improve.
Go for it. Easy to build. Can easily be improved upon but get the job done.
