Stop in for a cup of coffee
1/2 bench cleaned. Got a call, decided to go for a ride and qualify a 37 Fargo for collector plates. 8 years i think he said. Was his grandmother’s brothers truck, hes 2nd owner. Built from the ground up, sbc stroker,automatic with overdrive. Dually. This thing is wide!
I have a dually axle and now I am sure I don't want to use it. Going for the Super single look
Question for the car stereo folks.
My 64 valiant rag top. Only has the 6x9 dash speaker.
I was thinking of Two 3" rounds. Wolfs or tweet. Or one of each?
I'm not planing on any rear speakers at this time.
co-axial if they have them that small.. or 1 good 6x9.. 2 3's probably won't be better than 1 6x9 since you won't really get a stereo field anyway
I figure i will probably end up with a bluetooth speaker or something myself if i ever get that far.. the am radio works but no antenna anymore..
BTW.. make sure to measure your available depth before ordering anything
They are coaxef flat top.
The only thing in 6 x 9 seems to all be raised top. They won't work.
You need a special speaker for blue tooth? Or am I misreading?
a bluetoorh speaker has the amp and everthing in the speaker then you just send music from your phone wirelessly... i use one every morning getting ready for work.. surprisingly loud but not made for car speaker openings.. i will need to research that for myself though
This is the one i use daily. but not in the car, actually in the shower... shockingly loud with great bass and pretty small.. battery holds for bout 12 hours
Sounds good. Appreciate It.
There are actually some amazing android lcd head units with bluetooth car setups now... and not expensive.. i was thinkning of just putting the lcd i the glovebox.. basically can put any music on them or stream music or radio stations
