8.8 swap questions
AARDUSTER
NEBRASKA
Hello everyone. I was wondering if anyone could help me with a few questions. I read the other post about the 8.8 swap but I found it a bit difficult to fully track all the questions and replies. Here is my info: 1974 Duster original slant six manual 3 speed on the floor. Swapping in an early 1970’s 360 (motor is stock except for a cam that is a little bigger than a 340 factory cam) and a 4 speed from a 1975 Duster. I like the idea of the 8.8 swap as I am on a budget and it seems like a good upgrade over the 7.25 that’s currently in my car.
1) the local u pull it has these explorers 1999, 2000, 2002, 2004 & 2016. Can any of these be used?
2) does the 8.8 have to be shortened? It’s not going to be driven hard (no drag strip or full throttle launches)
3) can the Duster driveshaft (slant six) be used if it is the correct length? If not should I also take the driveshaft from the donor vehicle
Thanks for any and all help, advice and suggestions
The 99, maybe the 2000 will work. The rest are IRS cars.. It does not need to be shortened to fit. That said, I’m doing an 8.8 swap and I am shortening the passenger side to have the driver side axle. That will make the rear 1/2 less wide than a standard 8 3/4. I figured I could use wheel spacers if needed. Here is a good video: Google Search
Thanks very much for the reply! Greatly appreciated. I’m really looking forward to finally working on the Duster again. Been 15 years since I have turned a wrench on it
No problem. There aregood YouTube videos out there for shortening the rear if you are looking do that. I cannot say if you can have your driveshaft reworked but as you can see in the video I sent, the flange is different on an 8.8
I’ll definitely watch the videos several times!
