ddart cart
I’m at the valve springs to change the seals for my 360 swap. Head off, I cannot budge the springs with the Lisle compressor, and feel like any more force will break or damage something. I can get the spring to slightly lift from the bottom, but will not depress at all to reveal the keepers up top. You need 2 hands to operate the tool, but it will release if you let go. I was just testing if the tool worked like I thought it should (it doesn’t), and didn’t even figure out where the extra hands are coming from to catch the keepers, and reinsert them while I bear down with all my might, on this tool/spring. The $30 spigot knob type look like you can actually let go once compressed, this $50 compressor seems like it wants to hurt something, and doesn’t compress anything with me using it. I’m pushing the upper lever forward to compress, maybe orient the upper handle so I pull down toward the other handle? I’m a strong guy btw.
So is this thing a pos, am I using it wrong (probably), or do I really need a helper to remove springs? Lisle valve spring compressor:
