Your nuts. The jury isn’t out on anything.
Every internal combustion engine KNOWN TO MAN wants LESS timing at peak torque and MORE timing at peak power.
So how does a locked or all in by 2500 curve do that?
Explain it in your own words, in detail so we can all learn how physics has changed.
Saying that, there are SOME instances where a timing curve won’t make a difference.
@TT5.9mag has a jet boat. He wouldn’t see any help from a curve.
I apologize to Joe because I forgot his log in but he has the beautiful blue RR with two toilets on it is another example of where a curve won’t show much of an improvement in ET or MPH because he has a trans brake and his converter stall speed is above peak torque.
BUT, that doesn’t mean that a curve would slow either one down.
To actually determine what the curve should look like takes me about an half an hour on the dyno and several more hours (less if it’s not too complicated) to make the distributor have the correct curve.
But to make the claim the jury is still out is complete and utter nonsense.
The physics haven’t changed. Or maybe they have. I’m expecting you will be able to explain that change.
