Random assortment of stuff I have used and still use.
Yes, I understand that caster is calculated. I don't know the formula for calculating caster from caster swings though. I guess I should have asked Rusty how he was "calculating" caster with the tools he was using. I did fabricate a tool to measure caster directly for a project I was doing.RE-read what I posted. Caster is not MEASURED. CAMBER (tilt) is measured, and caster is CALCULATED from two readings. No "caster" gauge actually measures caster. The gauge CALCULATES it by the same method. My decades old Ammco caster/ camber gauge works like a circular slide rule.
If you get a good angle/ tilt gauge you can calculate caster
Easy. The complication comes when you get away from the "common" measurement with the wheels "in" and then "out" at 20 degrees from straight ahead. You take camber (tilt) readings at those wheel turn angles, subtract them, and then multiply by 1.5. That is your caster. If you for some reason do not or can not turn the wheels 20, then you'll have to search up the formula for different angles. It's just not that hard.Yes, I understand that caster is calculated. I don't know the formula for calculating caster from caster swings though. I guess I should have asked Rusty how he was "calculating" caster with the tools he was using. I did fabricate a tool to measure caster directly for a project I was doing.
With a level and an angle finder. Sorry, I missed it till now.How do you set caster?
Longacre gauge....
You can attach the gauge to the flat spot on the wheel hub or do as I did and make a mount.....
My old Ammco has no such centering deviceWhen I was younger I used to use one of these (Hunter brand, I think), so I know how those work:
One thing I've noticed in all of the newer gauges posted on this thread is that the lack the spring-loaded needle-like pin that sticks out of the mounting surface, and is used to locate the center of the axle:
I always thought that ensuring concentricity was important to getting accurate measurements.
Is there a different way that those other gauges do that?
Thanks,
– Eric
Thanks,
– Eric
For camber the gauge just has to be parallel to the face of the wheel, the angle is the same across the whole plane so it can be anywhere you can get the gauge parallel to the wheel face.
For caster, because you're actually subtracting two different camber readings, you end up canceling out any input you might get from not being centered because the gauge is staying the same distance from the axis.
The centering pin, I believe, probably has more to do with making it hard for the gauge to move around during the measurement. An extra safety on the magnetic attachment. One of those nice things to have that isn't essential that has likely been deleted for cost. I'm just thinking out loud though.
Also just thinking outloud. I don't think it would matter on caster swings where the gauge is vertically as long as it is still centered with the hub. I'm not sure if that would hold true horizontally or front to back for caster swings. In my head I'm picturing an extreme for effect. If the gauge could be slid back from centered all the way to near the bead of the tire. I'm not sure it would read the same. I know this is not a realistic example, just an extreme for the thought experiment.For camber the gauge just has to be parallel to the face of the wheel, the angle is the same across the whole plane so it can be anywhere you can get the gauge parallel to the wheel face.
Okay. That makes sense. I never tried to work any of this out on paper (if I could even remember how to - Geometry was a LOOOOOOONG time ago), so that's helpful.
Probably needed if you want to check for runout, though. I don't remember whether that was part of the process, but I do remember adjusting a thumbwheel that moved one level tube, then rotating the wheel and doing that again. I think. It's been like 30 years...
- Eric
I've used 2 sheets of steel w/gear oil, but that sounds like an easier clean up, especially Crisco type lube. & throw away tiles if you want. How much is a box now?I use 2 vinyl kitchen tiles each side, shiny side together, canola, mazola, crisco, whatever between as lube.
Washes up/storage is easy .
Interesting. I wish the link gave more info about how it works. Seems almost like magic.I’ve never done my own alignments yet but am planning on doing one some time this summer. I plan to get one of these.
Gyraline Align-It-Yourself Kit
