mcm95403
Member
I'm looking at getting a strip dominator modded for MPI use on a 318 Magnum, but wondering what can be done about the bypass hose port not being a direct match-up for the Magnum water pump port.
I'm guessing the t-stat outlet won't be as much of a problem, but not much room to work with the bypass.
I'd use EQ heads with the LA bolt pattern to solve that issue as well.
