Picked up a new Timing Light, and I checked Initial on the 360. With my old Timing light nothing would show, but the new one briefly showed a timing mark at idle 10-12 degrees. I only got to see the mark for a second, and it went away. Why? Is it the cheap 7mm wires (pretty old but new) I bought on Clearance from Rock Auto? I checked the Coil positive in the run position and it seemed a little low with my test light and it seemed a little dim. I suspect there is not enough juice going through the wiring- 74 Duster-Thanks for any help
