Mild 340 build runs hot
its listed for a small block mustang 65'-70.....dumb question but does all 13" go into the lower hose, seems excessive.
Here is a proven fix that works for tight quarters running the serpentine belt setup, final setup was an 18" mechanical fan > no shroud on a high performance 440.
Solved the overheating issue of the previous electric fan setup.
